Author: Subject: Fuel Injection cut off switch.
Johnmor
posted on 19/9/06 at 04:36 PM Reply With Quote
My fuel injection system has, built into the ecu a system by which if the engine is not turning the fuel pump will not run. i.e. If the ignition is on the fuel pump will not start until the engine is turned.
does this meet SVA requirement or do i also need an inertia switch. There was not one fitted int he donor car, but i dont suppose that means much.
russbost
posted on 19/9/06 at 04:50 PM Reply With Quote
Don't recall any requirement for an inertia switch in SVA regs.
graememk
posted on 19/9/06 at 04:51 PM Reply With Quote
i bought one off ebay for £5
Agriv8
posted on 19/9/06 at 04:56 PM Reply With Quote
Did not fit one to mine - v8 hotwire injection even though there is one inline to the fuel pump for this system.
SVA man did not question.
regards
agriv8
tks
posted on 19/9/06 at 07:21 PM Reply With Quote
The mcu
measures rpm
as long as it measures rpm it will get the pump going.
by many accidents the engine stalls
and fuel pump cuts of.
but what if your keep going???
then with a broken fuel tube it would
spray fuel.
saying that that i have a BEC and they die soon sow i haven't fitted one.
i would have V8 i would do it..
an car engine to..
Tks
BKLOCO
posted on 19/9/06 at 07:46 PM Reply With Quote
You DO NOT need an inertia or any other fuel cut of switch for SVA.
The twat who was selling them on fleebay was claiming that you did but it is bu****it.
paulf
posted on 19/9/06 at 07:49 PM Reply With Quote
I fited one from a rover 400 to mine purely to feel safer in the event of an accident .I located it on the front of the scuttle and have had no false triggering of it as i was told may happen.
Paul
mark chandler
posted on 19/9/06 at 08:37 PM Reply With Quote
If you are worried about the fuel pump running on then a relay on the oil pressure switch sorts this and protects the engine, you just need to bypass when keying the ignition.
This is a good idea for carbs as well, hence SD1 rovers had it fitted as standard.
Anyway most EFI systems run the pump for 5 seconds when initially keyed and die when the revs drop to zero, including RV8 hotwire and flappy box !
NS Dev
posted on 20/9/06 at 12:13 AM Reply With Quote
yea, no need for inertia switch for sva.
nearly took the one off my sierra, it objected to my driving on rough roads, (though only a couple of times and they were heavy landings to be fair!)
nitram38
posted on 20/9/06 at 10:24 AM Reply With Quote
No requirement from sva, but for the cost, a worth while item.
You can put in a oil pressure switch jobby but it will probably cost the same.
Rover V8's had them fitted just above the oil filter . They were the most common cause of starting failures
