Author: Subject: setting ride height
doughie
posted on 26/9/06 at 12:55 PM Reply With Quote
setting ride height
am looking to fix new brackets to my chassis (after ive cut the old ones off)
what have people done to set the lower wishbone to horizontalwhen fixing the upper shock mount (theres no adjustment) and set the rear ride height??
all replies greatfully received
Gunner1
posted on 26/9/06 at 02:51 PM Reply With Quote
This is difficult as without being able to adjust your ride height, it will change depending on whether you or any one else is in the car.
I suggest that you set six inch blocks under the frame, (lower wishbones pointed slightly down from the inner pivots) load it up to the corner weights that you expect when fully loaded and occupied. Install your uppers and have them pointing down from the pivots as you see fit and gives you the desired camber and castor. Next put the shocks and place on the lower pivot and pry a large bar under your frame to lever the top of the shock down until the body just starts to lift on that corner.
That shoud locate your upper shock mount......
Suggest also that if you cannot adjust your ride height with the shock spring that you add a couple of holes to the upper shock mount to raise or lower the car..
Good luck!
