Author: Subject: catch tank
rjs
posted on 3/10/06 at 05:47 PM Reply With Quote
catch tank
oil catch tank made from a kids £2 metal drink bottle & 10mm plumbers fittings & a breather filter that was already fitted .
SeaBass
posted on 3/10/06 at 05:54 PM Reply With Quote
Looks great but wait for oil to seep out of the rivets...
rjs
posted on 3/10/06 at 06:01 PM Reply With Quote
thought of that . shouldnt be a problem sealed on the inside with j.b weld & preasure tested.
peterriley2
posted on 3/10/06 at 06:22 PM Reply With Quote
that is brilliant, certainly in the locost spirit somewhat forgotten nowadays...
Joel
If you dont respect yourself, dont expect respect from anyone else
Live your dreams, dont dream your life
Women only want you for one thing- everything!
Fred W B
posted on 3/10/06 at 07:06 PM Reply With Quote
Are those actually real Meccano parts you have used for the lower mounts?
If so, first time I've seen that
Fred
soggy 3
posted on 4/10/06 at 02:56 AM Reply With Quote
mine is a £3 stainless sugar tin
will try and find as pic.
posted on 4/10/06 at 09:24 AM Reply With Quote
pah, you spent how much?
I use a tin for kit kat chunks; ok, spent a bit more maybe since I fitted a drain tap to the base. will also get piccy.
NS Dev
posted on 4/10/06 at 09:44 AM Reply With Quote
mine is 1 ltr beer can, lighter and cheaper still!
(I do the whole locost thing, despite the impression I can give at times!)
soggy 3
posted on 4/10/06 at 04:15 PM Reply With Quote
Here,s one
grusks
posted on 5/10/06 at 09:52 PM Reply With Quote
Heres mine.
[Edited on 5/10/06 by grusks]
Need More Money
posted on 12/10/06 at 09:18 AM Reply With Quote
as promised, my oil catch tank.
what makes it superior to the other designs is that there is a domestic radiator drain tap fitted to the bottom (that you can't see) . (and before someone points it out, I know the rivets are potentially leaky but once I see oil coming out of them, it is time to drain!
oil catch tank
oil catch tank
the insulation tape holding the lid in place is probalby not the best way so if you have a better idea, then let me know.
soggy 3
posted on 12/10/06 at 09:41 AM Reply With Quote
I welded in a drain in the bottom of mine just need to undo a bolt to drain it.
If the lid doesnt need to come off again araldite it on?.
