Author: Subject: Boot fails.
Dusty
posted on 6/10/06 at 11:14 AM Reply With Quote
Boot fails.
My desktop is having boot problems. Switch on and despite fans and lights it dont boot. No beeps. No whirr from the floppy.
Press hard reboot button, wait, press again and it boots as normal with one beep and loads XP which works fine.
Any ideas what is going on?
mookaloid
posted on 6/10/06 at 11:55 AM Reply With Quote
There are people who know more about this stuff on here than me, but it sounds like hardware to me. I had something similar once and it was the on/off switch!
ecosse
posted on 6/10/06 at 12:00 PM Reply With Quote
If its not reaching post it could be either PSU or Mobo, more likely PSU if does eventually boot as mobo failures tend to be terminal.
Do you have a lot of extra cards in the PC or USB devices connected?
Alex
RazMan
posted on 6/10/06 at 12:12 PM Reply With Quote
Just had a similar problem with one of my Shuttles. It was the psu going intermittent. Unfortunately the Shuttle jobbies are quite expensive at £45 but if yours is a standard PC you can probably pick one up for about half that.
Raz
Spyderman
posted on 6/10/06 at 12:51 PM Reply With Quote
I've had similar problems when the processor fan started failing. Sometimes it would need two or three resets before booting up.
Spyderman
Dusty
posted on 6/10/06 at 01:24 PM Reply With Quote
Usb cardreader and mouse. Only card is the video card. One cd writer and one floppy disk. 1 Gig of ram and 2800sempron.
posted on 6/10/06 at 02:32 PM Reply With Quote
Bios battery still alive?
posted on 6/10/06 at 02:40 PM Reply With Quote
Sounds very much like PSU - has a strange acrid smell been eminating from it lately? They suck all sorts of sh!t into them and they rarely get looked at... hope it's not took MB with it (mine did!)
Good luck
pbura
posted on 6/10/06 at 05:44 PM Reply With Quote
Sounds like your PSU is not sending a "power good" signal to the motherboard, hence the non-boot. Hitting the reset button provides a fake signal, so up she goes.
The lack of signal could well be due to uneven voltage (not good for your computer) so it's best to not run it using the reset trick.
Something you could try is reseating the power supply plug into the mobo. The power good signal comes from the orange wire, so you might take a good look at that one.
BoL!
Pete
graememk
posted on 6/10/06 at 06:18 PM Reply With Quote
i'll post you a new one for £10 if you like 400w
graeme
