Author: Subject: Oil Pressure Sender
richyo
posted on 6/10/06 at 12:12 PM Reply With Quote
Oil Pressure Sender
Might be in the wrong section but here goes.
I'm fitting an oil pressure gauge and want to know if I attach the oil warning light wire (from the light on the dash) to the same connector that the oil pressure wire attaches to ?
TIA
Richyo
tks
posted on 6/10/06 at 12:25 PM Reply With Quote
No!
An sensor is one thing..
in fact it can measure a RANGE from pressures..sow the signal it gives is relative to the measured value.
A Low pressure SWITCH is just a switch wich provide ground to a bulb.
It has only one setpoint! and below that value it switches on.
Sow the answer is no, don't connect the bulb to the sensor.
Tks
