Author: Subject: Help With Picking New Welder
tri
posted on 10/10/06 at 08:42 PM Reply With Quote
Looking to start welding saw this one and thought it would be good to start with but also beable to keep me once i can weld this is the top end of budget so any coments or ideas would be helpful.
http://www.machinemart.co.uk/product.asp?p=010115161&r=2031&g=105
Cheers Tri
[Edited on 10/10/06 by tri]
posted on 10/10/06 at 09:10 PM Reply With Quote
i got a 135 clark one and it works just fine. Not a bad buy IMHO, considering the price.
thunderace
posted on 10/10/06 at 10:27 PM Reply With Quote
http://www.mig-welding.co.uk/
i would say all you ever need is a mig 90 for work up to 4mm.
zetec7
posted on 10/10/06 at 11:49 PM Reply With Quote
I've got an old Clarke 130EN Turbo, and it works great. I've done my whole frame and chassis with it without problems. Tons of penetration if you go slow, even in heavy 3/16" plate. The Clarke 160 has significantly more power than mine, so it should be excellent for a build!
Gav
posted on 11/10/06 at 08:06 AM Reply With Quote
I have one and it is an excellent hobby welder for the price, did my entire chassis without a hitch, iirc it comes with a proper regulator for big refillable bottles so if your planning on using the small throw away onesyou will have to buy a the regulator for that, iirc they are about a tenner from machine mart.
lexi
posted on 21/10/06 at 01:46 PM Reply With Quote
If you check Northern Tools Ebay site you will get the same welder for £159 plus 15 quid post.......be quick as they will go!
Alex
phelpsa
posted on 22/10/06 at 11:43 AM Reply With Quote
I have a 151TE Turbo and it's perfect for locost work! It will weld whatever you throw at it steel wise, and has lasted both my uncles and my abuse!
Adam
