goodguydrew
posted on 12/10/06 at 01:17 PM |
Sierra front hubs on book chassis
Here's a question. Since the supply of Cortina front hubs is illusive (please offer me a pair ), can Sierra hubs be used on a book chassis?
If they can, what design of front wishbones should I use?
Thanks guys.
mistergrumpy
posted on 12/10/06 at 02:39 PM |
Yes you can and use the same design wishbones. You will need mushroom adaptors to narrow down the hole that was formally for the strut so that it
acceots your transit rod end. You can buy them from gts tuning
posted on 12/10/06 at 04:42 PM |
Sierra uprights are not directly interchangeable with Cortina uprights without altering the wishbones. To use the Sierra uprights and retain the same
overall front track width, you will need to use shorter top wishbones. Alternatively you could lengthen the lower wishbones and increase the front
track width.
I'm sure some of the locost part manufacturers sell suitable wishbones for book chassis with Sierra uprights.
big_wasa
posted on 12/10/06 at 05:58 PM |
Can any one tell me how much shorter the top bones should be ?
Would be maga greatfull
Uphill Racer
posted on 12/10/06 at 11:32 PM |
Getting the camber back is easy, camber change, steer arm and bump steer is another matter
jwallbank
posted on 25/10/06 at 08:36 PM |
Sierra Uprights
Further on the subject of using Sierra front uprights, what bottom ball joints will fit - have tried Maxi and they are way off and can't seem to
find a drill or reamer to machine them to fit - any ideas out there?
flak monkey
posted on 25/10/06 at 08:40 PM |
jwallbank you dont happen to work at warwick uni do you?
Sera
http://www.motosera.com
jwallbank
posted on 25/10/06 at 08:53 PM |
Sierra Front Uprights
Sorry, live in Lancashire
flak monkey
posted on 25/10/06 at 08:55 PM |
Lol, OK. Just I have a lecturer called Jim Wallbank at uni (I think he originally came from lancashire actually ). Was just curious thats all
Sera
