RazMan
posted on 19/10/06 at 08:39 AM |
Painting brake discs?
After a year of sitting in the garage (on the car) my brand new discs have now got a thin layer of surface rust on them and now look decidedly second
hand Even worse, they are clearly visible through my Compomotive rims. I realise the pad area will be nice and shiny after a few presses of the
brake pedal but everything else will remain rusty.
What is the best way to pretty them up a bit? Hammerite ok?
Raz
posted on 19/10/06 at 08:47 AM |
I've used silver paint similar to hammerite on my volvo discs and kit car - so far it is still on. If you foresee getting you disc red hot,
then proably no paint will survive that - maybe High temp paint would be better?
NS Dev
posted on 19/10/06 at 08:56 AM |
yep use high temp paint, black exhaust paint from halfrauds is pretty good stuff, I do all my brake bits with it, certainly unless you drive very
slowly or never brake any normal paint will soon burn off the discs.
mookaloid
posted on 19/10/06 at 08:57 AM |
I wire brushed the rust off then used Halfords Hi temp stuff.
Most paint will come off in due course so i regard this as something to be done once a year or so.
Mark
[Edited on 19/10/06 by mookaloid]
RazMan
posted on 19/10/06 at 10:02 AM |
Thanks guys - I'll nip into Halfrauds later
Raz
Sirius
posted on 19/10/06 at 12:45 PM |
I've had good results with Sperex VHT spray paint, comes in a few colours aswell including silver.
I got mine from the local motor factors. ![](/images//smilies/smile.gif)
C10CoryM
posted on 19/10/06 at 02:02 PM |
Mask off the clamping area where the rim touches the rotor. Paint is just like dirt and can cause clamping forces to be reduced over time. Probably
not an issue in this case, but may as well avoid it.
"Our watchword evermore shall be: The Maple Leaf Forever!"
RazMan
posted on 19/10/06 at 02:17 PM |
Good point - I had a strange wheel wobble on my Nissan which turned out to be a very thick coat of paint on the disc mating surface causing a small
amount of runout. I sanded the paint off and all was well again.
Raz
andyps
posted on 19/10/06 at 09:32 PM |
Before I fitted new discs to my road car I masked and painted them with exhaust paint from Halfords. It needed curing so I stuck them in the oven for
a while to help it set, they stayed nice and rust free for two years. Didn't have the time last time and the disks have gone rusty very quickly.
