Author: Subject: pinto sump
auzziejim
posted on 21/10/06 at 05:40 PM Reply With Quote
pinto sump
im in need of a shortened pinto sump but (and here's the catch) it must be cheap. im totally broke due to various things and need a sump that doesnt leak so i can run my engine, tune the carbs and set the timing etc etc
please help
cheers
james
[Edited on 21/10/06 by auzziejim]
JackNco
posted on 21/10/06 at 06:01 PM Reply With Quote
how cheaps cheap?
Tiger do a zetec sump for 180+Vat i think so i assume a pinto would be around the same, if you find cheaper ide be VERY interested!
John
Some people are worried about the difference between right and wrong. I'm worried about the difference between wrong and fun.
O'Rourke, P.J. (1989), Holidays in hell. London (Picador)
posted on 21/10/06 at 06:27 PM Reply With Quote
If it's not on the road put a standard one on till you get it sorted then shorten it when you are ready. My pinto sump is not shortened and doesn't cause any problems and there are some mighty speed bumps round here. I have about 4" of clearance under the sump.
andyace
posted on 21/10/06 at 07:32 PM Reply With Quote
EBay
They come up on ebay often, expect to pay around £100 though. Currently :
http://cgi.ebay.co.uk/ford-escort-rs2000-mk1-2-alloy-sump_W0QQitemZ320037871832QQihZ011QQcategoryZ21654QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/RS-ALLOY-SUMP-AND-PICK-UP_W0QQitemZ170040478293QQihZ007QQcategoryZ27377QQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/RS2000-MEXICO-MKII-ALLOY-SUMP_W0QQitemZ320040089659QQihZ011QQcategoryZ27377QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
dave r
posted on 21/10/06 at 08:09 PM Reply With Quote
have a word with bill on the rhocar site
he is local to you, and does a good job
flak monkey
posted on 21/10/06 at 08:38 PM Reply With Quote
I chopped my own and got a mate (a coded welder) to tig weld it up for a tenner. If you make the bits go up a small local fabrication place and get the to weld it up. If you go and speak to the right person they will do it while you wait (took my mate no more than 5mins to weld mine).
Sera
http://www.motosera.com
Pdlewis
posted on 21/10/06 at 09:03 PM Reply With Quote
How much is cheap? I have one on my 1.6 ive just taken out but not sure how much to let it go for
JackNco
posted on 21/10/06 at 09:05 PM Reply With Quote
Dunno if i keep missin u on msn or what. how did u measure up how much to chop off?
auzziejim
posted on 21/10/06 at 09:09 PM Reply With Quote
well i welded my own but the sump plug then got threaded so i had a failed attempt at rectifying the situation with the sump in situ but its now totally fubar my own fault i know.
iv seen the rs alloy ones but in not keen seeing as imo the alloy will crack on impact and steel will more likely dent or bend.
pd lewis let me know a price and i will let you know
cheers
james
flak monkey
posted on 21/10/06 at 09:56 PM Reply With Quote
I measured from the centre of the input shaft of the gearbox to the bottom of the bellhousing. Then worked out how much to chop off the sump - pretty simple to do.
Sera
JackNco
posted on 21/10/06 at 10:23 PM Reply With Quote
seems like one of these things thats easier said than done. but its a route i may look in to. im sure i can get it welded up pretty cheap.
Duncan Mould
posted on 27/10/06 at 10:27 PM Reply With Quote
shortened sump
I have shortened several pinto sumps in the rhocar fraternity as all 7 replicas suffer from ground clearance problems and find the operation to be relativly simple. I even add a small bunker on the side to aid oil capacity and have had no leaks so far.
I usually charge £30 and I will even spray it BLACK!
posted on 27/10/06 at 10:33 PM Reply With Quote
Is that your real name?
Duncan Mould
posted on 29/10/06 at 09:16 AM Reply With Quote
sumps
yes do I need a Code name?
posted on 29/10/06 at 09:26 AM Reply With Quote
No
that one's perfect. It reminded me of something I saw on ebay, Duncan molds , American spelling though.
HAL 1
Builder
Posts 226
Registered 5/2/06
Location bolton
Member Is Offline
Photo Archive Go!
Building: Built haldane 100, retirement project Marcos GT
posted on 30/10/06 at 07:01 PM Reply With Quote
There's one on e-bay now, look for item number 250043229598
