takumi
posted on 21/10/06 at 06:49 PM |
Alternative to Escort mk2 steering rack?
hi,
Im just browsing for parts I will be needing for my locost project..
Can anyone tell me if there is an alternative steering rack for the Escort Mk2 type?
Has anyone used another steering rack with success and what needed to be adjusted..
thanks
tak
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special
valves FR22 cam, 4- 1 header.
posted on 21/10/06 at 06:58 PM |
Lots of people have used the Sierra steering rack, but the rack and housing need to be shortened to get the correct geometry.
Jebus
posted on 21/10/06 at 07:26 PM |
hiya, i think that unless u have a reason not 2 use the escort rack then go for the escort 1, the quick ratio ones are meant to be nice and cheap and
they fit without any major mods.
TangoMan
posted on 23/10/06 at 04:14 PM |
I have a Cortina rack on mine. Fits a treat without the need for extended ends.
I did struggle recently though to find a replacement as mine failed MOT for play. Cortina was specified in the Formula 27 plans I have so I guess they
were common a few years ago.
Summer's here!!!!
