Author: Subject: Rally spec distributor
flak monkey
posted on 23/10/06 at 06:47 PM Reply With Quote
I have the opportunity to get a new distributor for my engine. The question is should I bother?
At the moment its fitted with a standard dizzy which will need to be modified to limit the total advance due to me needing more than standard at idle because of the fast road cam.
Or should I invest in what called a 'rally' spec distributor, which will give me 12deg advance at 1000rpm and a max of 36deg at 3700rpm? I might need to up the idle a bit to 14 deg, which will give me the apparent optimum of 38 deg all in mechanical advance.
I am guessing that the 'rally' spec dizzy will have a better advance curve than a modified standard one?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=005&item=150047025202
Sera
http://www.motosera.com
auzziejim
posted on 23/10/06 at 06:51 PM Reply With Quote
i spent my money at h+h ignition solutions
imo a much better product and its a standalone system which you will recieve set up ready to go with your current spec and you can send it back when you change anything engine wise foc
they can also supply a rev limiting rotor arm
tks
posted on 23/10/06 at 06:59 PM Reply With Quote
GO MEGA V3.0!
GO MEGA SQUIRT!
Clear as water
flak monkey
posted on 23/10/06 at 08:05 PM Reply With Quote
Megajolt looks like a hell of a lot of hassle to me. And it will probably end up costing considerably more than £100 as I dont have a laptop for a start, and i dont have any of the other parts available either. At a breif look it seems the megajolt would be £150, plus all the sensors and coil pack + leads. Then I need a laptop on top of that... And I would like the car to be running and on the road by next easter, which only gives me 2 months working time as I am away at uni...
Anyone else help with the dizzy? I have sent an email to H&H.
Sera
flak monkey
posted on 24/10/06 at 05:00 PM Reply With Quote
Thanks for the tip, H&H have been very helpful the last day answering my emails always within an hour. Their product looks excellent too, and they seem to know exactly what they are talking about. They will end up with my money too...
http://www.h-h-ignitionsolutions.co.uk
Sera
auzziejim
posted on 24/10/06 at 06:26 PM Reply With Quote
glad to help mate, if you say you were reccomended them by old skool ford you may also get a discount
flak monkey
posted on 19/11/06 at 05:51 PM Reply With Quote
Finally got around to ordering it and it arrived within a couple of days:
Well recommended
Sera
