Author: Subject: Pinto problem?
ady8077
posted on 29/10/06 at 06:14 PM Reply With Quote
Pinto problem?
Hi all
Whilst tinkering with the engine today i thought i would see how hot the exhaust is with my new infrared thermomiter, when pointed at cyl 1 ( near manifold ) it only showed 100 deg c, cyl 2,3 and 4 were 200
I cheaked the carbs (twin 45's ) and all jets seemed clear and the plugs all looked the same too
It was idling ok, but i didn't have time to take it for a drive, any ideas what else to look for?
Adrian
oliwb
posted on 29/10/06 at 06:18 PM Reply With Quote
I think, if its not affecting the idle or the way it drives you should write it off as metering error, perhaps the block is absorbing more heat at that cylinder, or maybe you didn't aim it quit right or something.....If it is affecting the drive then its time to investigate.....my guess would be too much fuel...also what type of ignition are you running as sometimes if its a 36-1 tooth wheel the crank/cam can stretch very slightly which would give a slightly different advance....don't imagine you'd ever notice it in the real world though! Oli.
posted on 29/10/06 at 06:20 PM Reply With Quote
Was there any reason for checking the exhaust or were you just curious. If it runs o.k. why look for problems?
ady8077
posted on 29/10/06 at 06:31 PM Reply With Quote
Hi
Just curious really, i've fitted an air box which has made it a bit awkward to balance the carbs, i thought measuring the exhaust temp might be a quick check
Adrian
posted on 29/10/06 at 10:35 PM Reply With Quote
if you are measuring the tem pon the exhaust manifold istelf, then that is strnge. I can;t see how the exhasuts from cyl 1 would not get as hot as the others.
have you looked at the spark plugs?
is there a vacuum take off on carb for cyl 1?
after a short run, did you measure again?
does the exhaust sound even?
tbh if it runs fine, then don't worry; but it would be interesting to find out why.
Dusty
posted on 30/10/06 at 12:34 AM Reply With Quote
Assuming the reading is correct then carb balance, mixture or missfire on 1 could all do that for you. Bet it would even up if you put a bit of load on rather than just run at idle.
ady8077
posted on 30/10/06 at 10:39 PM Reply With Quote
Hi guys
I'm probably worring over nothing, i'll hopefully get to drive it at the weekend and see
Adrian
