New Topic New Reply
Author: Subject: M18x1.5 Taps
kingr
posted on 30/5/03 at 11:30 AM Reply With Quote
M18x1.5 Taps
Having bought suitably threaded tube from the wonderful lolocost, only to find that it was so rusty that it wouldn't screw on anyway, I've now welded it in place, and there's no way in hell it's going to go on without retapping, money well spent then! Anyway, to get to the point, I asked about M18 x1.5 threads at a local engineering place and before I'd even got to saying the pitch of the thread, I'd got the rather shirty reply "M18 isn't an engineering size" hmmm, OK, whatever, automotive engineering doesn't count as engineering then? What I want to know is where can I beg/borrow/steal/buy a suitable tap from? What did everyone else do?
Kingr
posted on 30/5/03 at 11:57 AM Reply With Quote
Sounds like a load of tosh to me.
http://www.tapdie.com/html/metric-fine__taps.html list an M18x1.5 but you will need to contact them for single quanitiy pricing.
http://www.engineeringsupplies.com/shopping/shopdisplayproducts.asp?page=3 list them for £7.80 (probably +vat) and have online ordering.
Hope that helps.
westdown
posted on 30/5/03 at 01:37 PM Reply With Quote
Hi
Had same sort of problem borrwed one from a marine engineer seems they use that size.
Dave
ChrisW
posted on 30/5/03 at 03:01 PM Reply With Quote
I wouldn't put it down to the rust - the tubes I got from LoLo had the thread cut so badly they wouldn't screw in either. On taking them back to Lolo I was told 'if you're building a car like this we expect you to have a set of taps'. Duh? Why would I buy the tube from you then???? Bunch of idiots, especially the guy who runs the place. Steer well clear is my advice!!
Chris
My gaff my rules
Sparky
posted on 30/5/03 at 05:01 PM Reply With Quote
I found it was the same thread as the spark plugs used in the Ford SOHC.
I already had a rethreader for that purpose, so I managed to clean up the wishbone threads too!
Just thought you might like to know!
paulf
posted on 30/5/03 at 08:52 PM Reply With Quote
There is a company called Tracey tools in Devon that supply mail order.They stock all sizes of imperial and metric taps, dies, reamers, cutters etc.Most of there stuff is carbon steel which is perfectly adequate for our type of use.The last time I bought from them i ordered by phone and it came the next day. There prices are very good and a tap will be no more than about
£5.
If you cant find there address I will look it up tommorow.
Paul.
Kingr
craig1410
posted on 30/5/03 at 11:05 PM Reply With Quote
I had the same problem with the Lolocost wishbones and had to spend some time cleaning them up. I didn't need to recut the threads though and just used loads of WD40 initially and then used fine carborundum paste on the threads and screwed them in and out a good few times until they were nice and free. I then cleaned them out with brake cleaner and oiled them up to avoid them rusting again while I'm building the car.
The finish of Lolocost wishbones is very poor but the welding looks strong so it's okay I guess. The biggest downside of these wishbones is being stuck with Nylon bushes. If anyone knows of Poly bushes which fit these bush tubes then please let me know!
Craig.
chrisg
posted on 1/6/03 at 06:33 PM Reply With Quote
If none of the above works, try a motorbike jumble, thats where I got mine, and I had the pick of about 5 stalls, must be a common 'bike size.
You're welcome to borrow mine but don't think I'm walking to somerset with it!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
stephen_gusterson
posted on 1/6/03 at 10:38 PM Reply With Quote
engineering supplies do them. very helpful company.
the young lady (family owned business) that runs the site is really helpful, and even sent me a free mars bar with it cos of a small mix up on her part. But then thats my charm
atb
steve
Hornet
posted on 2/6/03 at 07:58 AM Reply With Quote
Loads of good answers...
Here's another, tap size is same as used on pneumatic cylinders, should be able to get a tap from anyone who uses this kind of stuff.
kingr
posted on 2/6/03 at 09:29 AM Reply With Quote
Thanks for all your replies, I'll be putting an order in with one of the companies you suggested this morning. Who would have thought there were so many uses for M18 fine threads?
Kingr
New Topic New Reply
