se7ensport
posted on 4/11/06 at 08:28 PM |
Pinto sump swap
quick question; I've got an rs2000 sump i'm planning on fitting tomorrow, other than shortening the oil pick up pipe and using new longer
bolts is there anything else I should be aware of????
Alex
auzziejim
posted on 4/11/06 at 08:47 PM |
i'd have a new gasket at the ready
how new is the pump too?
se7ensport
posted on 4/11/06 at 08:58 PM |
I have gasket kit and engine has only done 200miles.
cheers
Alex
mookaloid
posted on 5/11/06 at 11:05 AM |
Alex
Yes - the oil pickup pipe is completly different and it not simply a matter of shortening your existing one.
I would suggest you try and find the correct one or be prepared for a really tricky problem
Mark
se7ensport
posted on 5/11/06 at 04:05 PM |
thanks, just read it too late
looks like I'll be putting tin sump back on till I can track down an rs2000 one, I was hoping to shorten but as you say its far from simple
looking at it.
Any ideas where I can get one? Burton don't sell them.
Alex
mookaloid
posted on 5/11/06 at 04:29 PM |
Thet come up on ebay from time to time. Sometimes only with the sump though!
I ended up with two sumps and one pick up for this reason. Made a small profit by cleaning the worst of the two sumps and reselling it.
Good Luck
Mark
se7ensport
posted on 26/11/06 at 05:19 PM |
To update the archive the other issues are:
1. starter motor will not fit straight back on, edge of sump needs to be modified, or get an rs2000 starter.
2. clutch cable routing is also different, it probably requires a different length release arm to align properly, although I got round it by cutting a
piece of tube at an angle so that the inner cable runs straight.
Additionally check that the base of the sump is flat, a previous owner had jacked the car up on the sump and dented it, the bottom ends runs very
close and caused it to grind! sump off, blow lamp and hammer fixed.
