scotty g
posted on 12/11/06 at 04:16 PM |
What size fuel line?
Hi all, a mate is fitting a sierra DOHC in his kit, keeping all the injection system. He doesn't know what size fuel line to use, what does
everyone else use?
Cheers.
RazMan
posted on 12/11/06 at 04:28 PM |
8mm would be plenty big enough
[Edited on 12-11-06 by RazMan]
Raz
John Bonnett
posted on 12/11/06 at 04:45 PM |
8mm or 5/16" should be fine for the feed but I believe the return can go down to 1/4" without any problems.
John
nludkin
posted on 12/11/06 at 06:32 PM |
I am using the same engine in my kit and a standard B&Q 8mm copper pipe for feed and return seems to work a treat.
seadog
posted on 12/11/06 at 08:40 PM |
Yep I second nludkin. I too used B&Q's 8mm microbore copper pipe from the plumbing section. I think it cost me around £12 for a 15 metre
length which will be enough to run two lengths of fuel line twice comfortably.......I should know as like a twat I kinked my first effort buggering
about with it trying to get it through the holes of my diff brackets. Lets say I had more success second time round!!
![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Feel free to have a nose at the 'Build Diary Sept 2006' in my photo archive to see how I have run both the fuel & brake lines
[Edited on 12/11/06 by seadog]
