Author: Subject: Durite Fog Light Switch Wiring
richyo
posted on 15/11/06 at 09:40 AM Reply With Quote
I'm trying to wire up the above and keep blowing fuses.
I have it wired as follows: supply to connector 3, fog light wire to connector 2B and earth to connector 7. I have "piggy backed" connector 2B to connector 9.
Does that sound right or have I made a school boy error.
Any help appreciated as this is the last thing I need to do and I can forget about the electrics
TIA
Richyo
MartinDB
posted on 15/11/06 at 10:33 AM Reply With Quote
How's it connected at the fog light?
Is the supply to the bulb's pin or outer?
I kept blowing fuses until I realised the outer terminal of the bulb was earthed through the light housing and wasn't a good place to connect the supply too .
Martin.
