<<  1    2  >>
Author: Subject: Designing the perfect upright
nealg
posted on 16/11/06 at 02:27 PM Reply With Quote
Can any one design an ally upright
I am a pattern maker by trade and are willing
to model in cad and cnc the patterns free of charge.I can also get them cast at a local foundry in LM25(at a cost),but will need help for maching them.
I also need a supplier for the stub axels.
Any one out there interested
liam.mccaffrey
posted on 16/11/06 at 02:31 PM Reply With Quote
lm25; isnt that what k series blocks are made from
Build Blog
Build Photo Album
NS Dev
posted on 16/11/06 at 03:09 PM Reply With Quote
What sort of cost for casting them?
I'm very interested!!
Stubs are avaialble off the shelf in threaded from from several suppliers, Randall Motorsport do them for £23.50 each
nealg
posted on 16/11/06 at 03:43 PM Reply With Quote
The price will be between 12 and 15 pounds
per kilo,so it all depends on the design of the upright.They will also need heat treating I dont
now the price for this at present but the more
the cheaper
Syd Bridge
posted on 16/11/06 at 05:10 PM Reply With Quote
The thread on ali uprights on the MNR section is deleted. Pity.
Ali uprights, properly designed for impact and longevity in mind, and age hardening crystallisation, will end up near as heavy as Cortina items.
Much better to make your design and patterns for steel. Ends up lighter if properly done, and with none of the fatigue issues of aluminium.
Syd.
Hammerhead
posted on 16/11/06 at 06:38 PM Reply With Quote
have a look at lotus elise uprights, they are aluminium, I reckon they are cnc milled rather than cast though. I'd have a go at the design if you get stuck, but I am a product designer rather than an engineer. Anyway let me know if you want me involved.
Cheers.
Steven
peterriley2
posted on 16/11/06 at 09:48 PM Reply With Quote
rorty did cad designs of sierra uprights (same as cortina) to be made up as jigsaw puzzles. i think he was giving the cad drawings free so id check his posts or do a search for uprights. they werent corrected geometry or anyhing though, he will design a better geometry front end for use with vw golf parts, but needs people to size the parts. look on 'new locost front end' on the left hand side of the main screen, about 3rd under longest running threads.
Joel
If you dont respect yourself, dont expect respect from anyone else
Live your dreams, dont dream your life
Women only want you for one thing- everything!
short track 123
posted on 18/11/06 at 12:01 PM Reply With Quote
Uprights
nealg
You have U2U
posted on 18/11/06 at 09:54 PM Reply With Quote
Good point, but I thought they looked ever so fragile when I first saw them, and sure enough it's recommended that you reinforce the alloy uprights (at least on the S1) using available steel brackets if you are going to use them on track.
andyd
posted on 18/11/06 at 11:02 PM Reply With Quote
I know over time aluminium alloys can become fragile but what about if they have been hard anodised?
See here
"The hardcoat layer is equivalent to one of the hardest materials on earth: ruby"
I've also read that the hardcoat process can make the alloy as hard as steel. Would this not negate the usual fracture issues associated with untreated alloy?
Also see here
Also if the uprights are CNC'd from solid billet of a good strong alloy (6082) to begin with, would this also increase the robustness?
DIY Si
posted on 18/11/06 at 11:06 PM Reply With Quote
I think the coating process is just that, more of a wear resistance thing. It won' remove the fracture issue, which would start to occur in the centre, if I remember how it works right.
Sun Tzu, The Art of War
Browser
posted on 19/11/06 at 10:03 AM Reply With Quote
Hardness is not the same as fatigue resistance. They could be as hard as you like but still crack due to age.
Doug68
posted on 19/11/06 at 12:25 PM Reply With Quote
I'm using C5 Corvette uprights, they can be had on eBay for ~$100 a pop. There's only 2 types the front left is also the rear right and vis-versa
These are forged alloy with a bolt in bearing - stub axle sub assembly (this comes as one lump when replaced)
Without the bearing they weigh 2.2kg (includes top ball joint) and with the wheel bearing they are 6.6kg a throw. How does that compare against a Cortina or Granada upright?
The bearing / stub axle assemblies can be had as Timken parts for ~$170 each either front or rear and come with the ABS sensor.
I have no doubt that these are strong enough for the job.
I guess I've got 2 points here...
1. Theres strong production alloy parts available that don't cost a fortune.
2. Because of the web and eBay you can look further afield than the local wreckers / breakers for interesting items.
BTW 'Billet' means a big lump of metal 'Machined from billet' means machined from a big lump of metal. It means absolutely nothing in terms of the strength of the part.
for large machined alloy parts in the aircraft business they will often machine off the outside 1" or so all around a billet simply because the strength / grain structure is not consistent across the part due to the way the grains form in the material as it cools.
Most all of the serious high strength requirement alloy parts on aircraft are forged wherever possible.
None of which answers the original question, One way to go might be to look for parts of similar construction that you intend that are known to be able to take a beating. The Corvette may be one place to look, or possibly something low production like a 6R4 metro, RS200 Escort, TVR or DeTomasso (I'm guessing here) where there mightn't have been the quantity made to warrant forging.
Doug.
scotmac
posted on 20/11/06 at 06:54 PM Reply With Quote
Hmmm...here's one of those c5 uprights (for reference):
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320049510986
Here's another:
http://cgi.ebay.com/ebaymotors/97-04-c5-corvette-spindle-right-front_W0QQitemZ180051380879QQihZ008QQcategoryZ6763QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
They look pretty nice. Dont think they would work w/ my suspension geomety, tho. The steering arm looks about 2/5's of the way up the spindle, whereas sierra ones are about 1/5 of the way up (atleast my raceleda based sierra ones are). So, i would have to move the steering rack substantially!
-Scot
[Edited on 20/11/06 by scotmac]
bimbleuk
posted on 21/11/06 at 10:01 AM Reply With Quote
RE: elise uprights
If I remember correctly they are made from extruded sections similar to the chassis rails.
Yes the early alloy uprights should be reinforced if used on track with semi or full slick tyres. The lower track rod mounting point fractures. The later steel uprights are stronger and lighter!
andyd
posted on 21/11/06 at 11:35 AM Reply With Quote
Do you have any pictures or diagrams per chance? I was designing mine with alloy in mind but obviously don't want them to fall apart after a few miles. If I can achieve a similar weight using steel then I'll go for that instead.
Lippoman
posted on 21/11/06 at 05:53 PM Reply With Quote
Elise Forged Steel upright
The forged steel upright is a much stronger and more rigid unit, but not lighter. They are 3,5 lbs heavier than the aluminium ones (total for 4 uprights).
More detailed info can be found in the following PDF (from page 11 on).
ELise Upright
[Edited on 21/11/06 by Lippoman]
Syd Bridge
posted on 22/11/06 at 09:22 AM Reply With Quote
Well,Well, Well,
Halelujah Lord! At last someone has finally seen the light and decided that lightweight aluminium uprights are not suited for everyday road use!
And the mighty Lotus company at that!
They wouldn't have switched from Ali to steel for no good reason.
Syd.
posted on 22/11/06 at 12:00 PM Reply With Quote
It costs 30% less than the aluminium one, that's why they changed. The aluminium looks more trick though and doesn't need painting so it doesn't matter if it's you're going to die horribly in a mass of twisted metal as long as your cred stays high.
posted on 22/11/06 at 01:13 PM Reply With Quote
That's probably the main reason, but as said above it was found that the extruded alloy ones were marginal in terms of strength.
Doug68
posted on 23/11/06 at 03:37 AM Reply With Quote
University learnings for make education of glorious community of Locost Builder...
http://www.forging.org/members/docs/pdf/FIERF-AISIFinalExecutiveSummarySept04.pdf
Not really a fair test given the sponsor of the work and selection of test parts but intersting non the less.
dnmalc
posted on 23/11/06 at 08:26 PM Reply With Quote
with lots of people considering the use of Rorty's IRS had you considered making an equivalent rear upright. I am sure I'm not the onlyone who might be interested.
nealg
posted on 23/11/06 at 10:33 PM Reply With Quote
If someone will design a rear upright I will
cut the patterns at work but its the actual
machining of the cast uprights which I can not do
The main reason why I started the thread is
I am starting to design a 3 wheeler similar to
the vw gx3 so if there any designers out there
who can design some sort of rear hub assembly similar to the ducati 916 to hold a 18x9 wheel on a single sided swingarm let me know
scotmac
posted on 24/11/06 at 04:14 AM Reply With Quote
Right...a steel producer sponsoring the test, and making generic claims about the materials based on 3 very specific automotive items....all that really can be said is that for those three items, the steel one was by far the strongest. Much more interesting to see a less biased comparison of the metals themselves and their properties.
In general, it is my understanding that aluminum is
actually stronger than steel, for its weight...at least in certain uses. For example, both F1 and bicycles used aluminum for this exact reason, before switching to carbon fiber.
Cheers, -sm
NS Dev
posted on 24/11/06 at 08:39 AM Reply With Quote
No, not as simple as that I'm afraid!
Depends on what jointing processes are used, application, fatigue requirements etc etc etc.
benefits over a well designed steel structure are very minimal. The main problem with steel is using a small enough section to optimise the stresses in it, sometimes needs an unfeasibly small sectional area to allow for jointing etc, in just the same way as ally can be extremely strong, but when that alloy is welded it will fall apart! (in simple terms! )
<<  1    2  >>
