Author: Subject: digidash2lite
mac1ZR
posted on 19/11/06 at 02:00 PM Reply With Quote
digidash2lite
Hi all,
our digidash seems to just go through the initial demo mode like when it's first turned on,but keeps repeating this process over and over.Pressing the buttons does nothing, any ideas?
thanks
bigrich
posted on 19/11/06 at 02:25 PM Reply With Quote
sounds as though the dash has a fault.i would disconnect and reconnect all the blocks just to rule out water or a poor connection but it may need to go back to etb
stevetzoid
posted on 19/11/06 at 03:03 PM Reply With Quote
Try a seperate lead direct from the battery to rule out a wiring or earth problem, make sure the fuse is ok and no bad connections.
DarrenW
posted on 20/11/06 at 10:06 AM Reply With Quote
Its worth an email direct to ETB. John Gare is a fantastic bloke and normally very prompt at replying if hes in the office. That will then take the guess work out of it. If it is a faulty unit you wont have any bother with their after sales service - very very good in my experience.
Knowing your attention to detail with building its unlikely to be anything you have done wrong.
