mackei23b
posted on 28/11/06 at 04:57 PM |
Sierra Brakes (Rear Disks)
Hi there
I made an interesting discovery tonight when I put my pads in the rear calipers, the disc was not big enough!
On looking through the information I have found that I have the early Cosworth / RS500 disc brakes and not XR4x4 as initially thought!
The disks I have are 253mm solid discs and now require 273mm solid discs if I continue to use this set up.
My question for those of you that are running 253mm solid disks what are the measurements you have from the picture below as I am wondering if it is
only the caliper mounting bracket / slider that differentiates the 4x4 and Cosworth Parts?
If so then I might just change this and use my current discs / calipers.
I look forwards to hearing from you.
Many thanks
Ian
[Edited on 28/11/06 by mackei23b]
Hammerhead
posted on 28/11/06 at 05:00 PM |
I did that too!
The difference isn't in the calipers but the hub mounting brackets that attach to your rear uprights. Some cosworth ones were spaced further
that standard sierra ones.
I had already torqued up the hub nuts and didn't want to remove them so now I have 273mm rear discs.
Spin8Spin
posted on 28/11/06 at 05:12 PM |
i did it as well, i assumed it would be the caliper carying brackets that dictated the size of the disk, but after buying some new ones that definatly
came off a car with 253mm disks and still had the problem i came to the conclusion that its the hub/bearing carier's that are different on the
273 disk cars, so i am to just using the bigger disks as well for now.
Matt
mackei23b
Hi there
Many thanks, that explains things, I did think of that option as well, but hoped it was the caliper.
Oh wel, looks like larger discs, where did you get yours from?
Ian
Hammerhead
posted on 28/11/06 at 05:14 PM |
local motor factors for me. make sure you don't get the vented ones if you haven't got the larger vented calipers.
Spin8Spin
posted on 28/11/06 at 05:27 PM |
think i got mine from brakes international, thats where i've got most of my brake parts from
matt
mackei23b
posted on 28/11/06 at 05:38 PM |
Ian
