iiyama
posted on 29/11/06 at 04:52 PM |
Sierra diff
OK, how do I get the half shaft oil seals out? Tried prising them but Im getting no where. More brute force needed?? Or is there a trick to it?
If its broke, fix it. If it aint broke, take it apart and find out how it works!
snapper
posted on 29/11/06 at 05:48 PM |
They have a tight metal ring that inteferance fits like a bearing, you need to get even pressure either side. The inner bit you can get pliers or mini
mole grips on but its only rubber so bits get pulled of. Once you have got it moving a bit lever eitherside until the metal ring can be grabbed with
the mole grips. Its fiddly but better than nackering the bearing seal face.
iiyama
posted on 29/11/06 at 05:53 PM |
Thanks bud!
Indymike
posted on 29/11/06 at 08:09 PM |
I tried several things but ended up going to my local Ford dealer. They used a special tool to yank'm out. Was done in a couple of minutes and
didn't even charge me! They even let me borrow a drift to put the new seals in.
Build manual? What build manual?
