bigandy
posted on 3/12/06 at 03:57 PM |
VW Golf question
Afternoon folks. Does anyone on here have any knowledge of VW golfs? Specifically the 1.4litre ones from between 1991 and 1997?
I'm just trying to find out how their radiators were bolted down...
Dammit! Too many decisions....
budge
posted on 3/12/06 at 05:22 PM |
most Vw rads of that time that I've had apart were a couple of pins/lugs through something in the bottom, normally a rubber bush (but not
always) and the tops were a couple of straps again mostly secures in a similar way to the bottomand the other end was bolted to the slam panel with an
m6 bolt
posted on 3/12/06 at 05:44 PM |
With out looking can't be sure but I think there may be a couple of 10mm headed bolts holding the rad secuing brackets then disconnect and lift
out.
martyn_16v
posted on 3/12/06 at 07:13 PM |
^^^ what he said. Two bolts for the top two straps and then just lift it off the crossmember.
bigandy
posted on 4/12/06 at 11:46 AM |
Brilliant, thanks folks. I've got what I beleive to be a golf rad that fits my car, and I was wondering how to mount it as it has plastic end
caps, which I am reluctant to screw a bolt into
The rubber bush at the base, and bracket at the top should be doable though!
