Author: Subject: cat5 points how much?
skydivepaul
posted on 12/12/06 at 03:07 PM Reply With Quote
does anyone know the going rate for cat5 points installed
I am working on a project for a medium office that needs 30 x double points installed into existing dado trunking
cheers
Paul
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
carboncraft
posted on 12/12/06 at 03:16 PM Reply With Quote
Cat5 Sockets
Screwfix,
Wall socket plats 0.65 each
cat5 Outlets 19.48 for 10.
vinny1275
posted on 12/12/06 at 03:20 PM Reply With Quote
The company we use charge £90 + vat for each double socket (so 450 quid for 10 Cat5 points). That's for a small quantity though, so will probably get cheaper if you're putting in more...
Will get more expensive if you don't already have patch panels you'll need those as well.
HTH,
Vince
Guinness
posted on 12/12/06 at 03:21 PM Reply With Quote
My data company usually charges around £65 per twin outlet installed, wired back to cabinet, tested, labelled and warranted for 15 years.
Can put you in touch with a couple of firms if you want.
Mike
skydivepaul
posted on 12/12/06 at 03:48 PM Reply With Quote
thanks for the info. i have had quotes ranging from £60.00 - £90.00 per double point.
cheers
Paul
HD CCTV
IP security systems
scottc
posted on 12/12/06 at 05:15 PM Reply With Quote
which ever quote you go with make sure they test it and provide some sort of certificate.
If they're a decent company they be able to tell you the run lengths as well.
Might also want to think about running extra cables now for future expansion. You can leave them unterminated at each end. Cables cheap, and the pricey part is the labour.
carboncraft
posted on 12/12/06 at 07:00 PM Reply With Quote
If you have the trunking there, do it yourself its very easy and you can save loads of money, I cabled up our office 36 sockets onto patch panel, only 5 hours work. The longest job is running the cable.
McLannahan
posted on 12/12/06 at 08:31 PM Reply With Quote
Not that I'm undercutting but my cable guys charge £45 a socket!
I wire all mine myself now though. Costs do mount up so quickly and I've saved LOADS of money.
Feel free to give me a shout and I'll PM details of companies I used.
skydivepaul
posted on 13/12/06 at 10:45 AM Reply With Quote
thanks for all the information.
As always this site provides a mine of knowledge.
cheers
Paul
HD CCTV
IP security systems
