MikeR
posted on 12/12/06 at 10:18 PM |
Fault codes on Vauxhall Astra 98-2004 model
Has anyone got the s/w & wiring diagram for the astra ECU connection?
I've got an intermittent fault with my ABS / Traction control. Want to know what the computer says before i take it to a garage.
If not, anyone any idea where i can get a cheap but decent fault code reader?
sparrks
posted on 12/12/06 at 11:21 PM |
if you have pin 6 on dlc you can read the flash code on the mil lamp
the_fbi
posted on 13/12/06 at 12:22 AM |
http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm
MikeR
posted on 13/12/06 at 12:56 PM |
damn, my problem is ABS / Traction and the only fault code is "failed unit". Was hoping for failed sensor on wheel X as it also affects
the speedo when it fails, then it turns off traction / abs and speedo goes back to normal.
the_fbi
posted on 13/12/06 at 01:09 PM |
Worthwhile checking the wiring at the sensors, their connector which is probably on the shock body and blasting the sensor with water to clean them
up.
MikeR
posted on 13/12/06 at 06:15 PM |
had a quick look under the car in case i could see some wires hanging loose. Couldn't didn't really wnat to get too involved. I have very
little space to play with the real car & almost less motivation. Just wanted an idea of what to expect. Should look as its very irratic, usually
comes on after a period of driving, but hasn't done it for a few days.
