Zero 7
posted on 19/12/06 at 09:34 PM |
What thread is the Carpi/Cortina studs ?
Are they 3/8 unf or 7/16 unf or something altogether different .. ? Cheers Paul
jamesbond007ltk
posted on 19/12/06 at 09:39 PM |
Hmm... good question, will see if i can find my receipt from demon thieves...
jamesbond007ltk
posted on 19/12/06 at 09:45 PM |
According to here...
http://www.speedshack.co.uk/Wheelnuts.htm
Mk3/4/5 Tina's and Mk2 Escorts are M12x1.5
BUT
note that Mk 1 Escorts and Mk 1/2 Tina's are 7/16" UNF
Rich
liam.mccaffrey
posted on 19/12/06 at 09:47 PM |
beat me, they are metric M12x1.5
same as most (if not all) ford studs
EDIT
my tina mk3 ones are metric, i swapped them with longer granada ones
[Edited on 19/12/06 by liam.mccaffrey]
Build Blog
Build Photo Album
jamesbond007ltk
posted on 19/12/06 at 09:49 PM |
You gotta be quicker than that m8!
Although they do say i am good with my hands......:-)
Zero 7
posted on 19/12/06 at 09:56 PM |
There not metric ones they must be the 7/16 ones .... Thanks anyway will try get a bolt from work to make sure.
jamesbond007ltk
posted on 19/12/06 at 09:59 PM |
How can you be sure they are not metric ones?
What are you using to test it?
Dont forget you could be trying to thread an M12 nut onto an M12 stud but they may have a different pitch?
Also, if you are using an off-the-shelf M12 nut rather than a wheel nut, chances are its Metric coarse and not fine, as used on studs.
Zero 7
posted on 19/12/06 at 10:12 PM |
I just got a M12 x 1.5 bolt the same as the studs i thought i needed but will try a M12 x 1.25 tomorrow as well as a 7/16 cheers neway
posted on 20/12/06 at 11:56 AM |
Cortina wheels studs are metric From the introduction of the Mk3 ie October 1970 onwards.
Only Mk1 and Mk2 were UNF and they had struts at the front.
Escorts and Capris went metric slightly later circa mid 1972.
NS Dev
posted on 21/12/06 at 07:30 PM |
Peugeot use M12 x 1.25, ford certainly never have.
All will be M12 x 1.5 except the really old unf stuff
Bear in mind a std M12 bolt is 1.75 pitch not 1.5. (they come in 1.75, 1.5 and 1.25)
[Edited on 21/12/06 by NS Dev]
