stevetzoid
posted on 21/12/06 at 12:04 AM |
Compressor Oil
Evening All, I have just got hold of an old ingersol rand compressor reciprocating, looks like two stages or just twin, all I want to know is what oil
should I put in it.
Works great 150 psi not too noisy about 30 years old.
Regards Steve Evans.
stevetzoid
posted on 21/12/06 at 12:06 AM |
avator size
Sorry this is first posting since making avator work, looks a bit big.
Job for later.
theconrodkid
posted on 21/12/06 at 08:55 AM |
get the proper comp oil,most motor factors will sell it,i had an IR,50 odd years old and good as the day it was made
who cares who wins
pass the pork pies
posted on 21/12/06 at 09:19 AM |
It's a single grade compressor oil, 30 grade usually and it doesn't contain the detergents and additives in car oil.
stevetzoid
posted on 21/12/06 at 09:38 AM |
Thanks for the info, avator looks ok now.
Steve.
posted on 21/12/06 at 11:01 AM |
machine mart sell compressor oil; you also use it in air tools
hobbsy
posted on 21/12/06 at 11:17 AM |
So its definitely the same oil that you shove directly into the arse of tools that you put in the "sump" of compressors that take oil
themselves?
My recent purchase (100litre, 3hp) came with really crap instructions and referred to grades of oil I'd never heard of. But I do have some
"air tool oil" from Screwfix.
It makes sense that it should be the same as the compressor (if its not oil free) pumps a bit into the air to keep the tools lubed right?
Just checking before I use the wrong oil!
It also mentioned different grades well viscosities (I assume) for summer and winter - do you need to bother as are winters aren't *that* cold
or should I say our summers aren't that hot!
zetec7
posted on 21/12/06 at 04:00 PM |
I use 10W30 motor oil in mine (have done for decades), and it works great. The oil I have for my air tools is awfully thin for a compressor, I think.
If you're going to change types of oil, I'd try to get all the old oil out first, just to be sure there are no compatability problems
between lubricants.
http://www.freewebs.com/zetec7/
