Author: Subject: How does the Series Work?
greggors84
posted on 15/6/03 at 10:40 PM Reply With Quote
Hi i am looking to build a MK Indy, and although i wont be racing it straight away, i will be wanting to race it. How does the series work. Is there a locost category and how much are you allowed to spend?
What other classes are there and do they all race together?
How much do the races cost?
Chris
[Edited on 15/6/03 by greggors84]
steve26
posted on 16/6/03 at 02:10 PM Reply With Quote
Hi Chris, I can only really tell you about the Locost Formula as that is the one I race in. There are other formula you can compete in with a Locost Chassis (ie. RGB - Road Going Bike Engined). These are more flexible in terms of permitted modifications (also meaning more expensive) and chassis/suspension/engine configurations etc, and are often split into different classes competing alongside each other, normally determined by engine capacity.
If you enter the 750 MC's Locost race Formula there is just 1 class - i.e. identical regulations governing engine (1300 GT Crossflow), Chassis (Built to book Specification), Suspension (no IRS etc - ie. 'To Book' ). For a copy of the regs see:
http://www.locost-racing.co.uk/technical%20regs.htm
There is no set limit as to how much you are allowed to spend, however the concept of the Formula is designed to benefit the 'Amateur Constructor / Tuner' with no major professional assistance with the building or construction of the car.
If you are thinking about an MK Indy & r planning 2 enter the Locost Formula u need to check whether this chassis is permitted because I believe the rear is designed to run Independant Rear Suspension. MK should be able to tell u if this can be modified to run in the series, or whether they still produce a Locost chassis 'to book'.
This year there are 14 rounds in the championship, visiting various circuits including Silverstone, Donington, Brands Hatch, etc. Entry costs vary between about £90 to £170. If you want 2 find out more about the Formula u'r best bet is to try & get along to a race or two and chat to some competitors, check out the cars etc. In my experience most people are friendly & happy to give advice 2 newcomers. Next race is Cadwell Park on the 29th of this month. If u need any more info - just ask!
Best Regards,
Dan S - Locost 69
[Edited on 16/6/03 by steve26]
ned
posted on 16/6/03 at 03:00 PM Reply With Quote
An MK Indy won't be eligible for the locost 750mc series, though couuld be eligible for the Road Going Bike engined (RGB) series or the kitcar series. There are various classes, mainly based on engine capacity.
Check www.750mc.co.uk and click on formulae, that will give you a brief rundown of the formula, you can then see the regulaions for more detail on the spec's the cars have to be built to in order to be eligible etc.
Best of luck,
Ned.
beware, I've got yellow skin
