auzziejim
posted on 13/1/07 at 05:32 PM |
sierra main beam wiring
right i have the sierra main beam/indicator stalk in my car and have the later/thinner wires so can someone please explain, in laymans terms, how i
wire the stalk to operate the main beam and relays as im really struggling and this is the last wiring job to do
please help
james
posted on 13/1/07 at 06:06 PM |
Which wiring loom are you using?
Wire your lights through the relays then run the relay earths through your column switches, brown/yellow dip, brown/white main beam. Make sure you
have the earth from the left stalk to the right when you switch from side to headlight brown/black joining terminal 15s on older or 56s on later
(there are still two variations)
auzziejim
posted on 13/1/07 at 06:41 PM |
right well i have the sierra indicator stalk but not the light stalk. for lights im using an off/on/on toggle switch and have dip beam working. i need
to work out what the 4 brown wires that my main beam switch has do. one i think will ne permanent live for the main beam flash. then one must be a
live feed from dipped beam for normal main beam use on must be a feed to relay and on to lights and the other an earth?
are my assumptions right or am i totally off the mark?
james
posted on 13/1/07 at 07:24 PM |
I've got a description of a 2 relay (main and dipped) system for Sierra stalks on my website but thats probably not much use if you're not
using the lighting stalk and shows the connection to a STM loom anyway.......
Have you got a copy of the Sierra Haynes manual- the wiring diagram isn't great (black and white) but with that and a multimeter it is possible
to work out the connections you need..... Or that's what I did...
ps U2U me if not!! I know of a backup copy of the Haynes manual online. Obviously you need to own the original too for it not to be illegal.....
auzziejim
posted on 14/1/07 at 06:40 PM |
ben im even more confused now, lol
i forgot to mention im using the vicky green loom with the relay kit but still cant get my head around this
(told you i needed laymans terms )
james
