Author: Subject: Velocity - windscreen
jcs
posted on 15/1/07 at 08:36 PM Reply With Quote
After two years bulding the XT went for SVA today. Failed on windscreen!!! apparently the one supplied by the original Luego company was not of the correct standard. Although BS marked was not correct number and apparently was a building double glazing standard number. Has anyone else had this problem. I bought the windscreen as part of a comprehensive kit - delivered in January 2005 - I suggest other builders should check their screens for conformity.
posted on 15/1/07 at 08:47 PM Reply With Quote
Remember hearing someone else had the same problem. You may find a windscreen company might be able to cut one to pattern ? failing that a plant (as in diggers?) glazzing company
DanP
posted on 15/1/07 at 09:18 PM Reply With Quote
or of course you could just remove it for the test
rjs
posted on 15/1/07 at 09:23 PM Reply With Quote
i think i heard somthing a long the lines of there windscreen glass is the same glass as your shower screen .have a look here at OBP http://obp.uk.net/shop/product_info.php?products_id=102
[Edited on 15/1/07 by rjs]
jcs
posted on 15/1/07 at 09:32 PM Reply With Quote
Removing screen was not an option according to the SVA inspector - too obvious with washers and wipers & demisters fitted that windscreen would be replaced after test.
muzchap
posted on 16/1/07 at 09:17 AM Reply With Quote
OK CAN ANYBODY LOCAL LEND THIS CHAP A WINDSCREEN?
I personally don't have one - but have heard on SEVERAL occassions of this happening!
Might be worth phoning the new owners of Luego?
At the end of the day - the glass is to a standard to protect you, other road users and pedestrians. If you did put it back in after the SVA - might leave you open for all kinds of legal ramifications - should there ever be an incident (severely hope not).
Perhaps the new owners of Leugo will take pity and do a deal with you - if you don't ask, you don't get - so might be worth a phone call!
GOOD LUCK
Did you have any other problems @ SVA?
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
keith2lp
posted on 16/1/07 at 09:24 AM Reply With Quote
Hi
I had the same problem in 2005, I contacted luego and they could not supply one. I managed to get one cut with the correct markings from a local windscreen company who came out and cut on site for £95.
The tester said that I could not remove it for a retest so I had no other choice.
Keith
rjs
posted on 16/1/07 at 10:08 AM Reply With Quote
keith i see from here http://www.locostbuilders.co.uk/viewthread.php?tid=40040
you were told the same as me .
My car failed with BS6206 markings this is the bs spec for patio doors / shower screens etc. You will need it marked to BS857/ BS857/2 to pass.
not good enough to sell screens not up to the job .
James
posted on 16/1/07 at 10:18 AM Reply With Quote
Dangerous too!
As presumably shower glass isn't going to shatter in such a 'safe' way as laminated car glass.
James
tks
posted on 16/1/07 at 12:10 PM Reply With Quote
mhhhh
makes me thing what i would have.
In the day i brought it i also brought the windscreen but i´m sure mine also has a tempered glass tamped on. will look up the BS number.
now i have it staying there going without..
heater etc. etc. is to much for me..
Tks
freshy26
posted on 16/1/07 at 07:22 PM Reply With Quote
Thank god the old company director is no longer trading as a kit car manufactor.
I thought the cars were SVA approved, so how can they supply a windscreen which is not fit for the job.
jcs
posted on 16/1/07 at 07:28 PM Reply With Quote
Spoke to Dean at new Luego today who can supply the glass to the required standard - the option I am going for. I was most concerned on the way home (65miles) in case the glass shattered, fortunately my son was driving and wore a crash helmet. Certainly would not have been happy to keep the old glass.
As regards the test, which was at Southampton, found it very thorough. The chap that carried it out was very helpful and explained each part of the test as he went along, not quite the ordeal I was expecting.
rjs
posted on 16/1/07 at 07:50 PM Reply With Quote
out of interest how much do they want for the right glass ???
