cossiebri
posted on 16/1/07 at 04:11 PM |
Bike carbs on vx xe red top
A friend has the chance of a set of R1 carbs and a inlet manifold to suit vx xe/red top 2.0
Anyone know if the jetting has to be changed?to what? anyone do a kit ?
Or a better set of carbs off a different bike,or just go with webbers/dellorto's?
Ta....
(by the way the car is a (s)locost!)
upgraded from a 1600 xflow/4 sp box to xe/type 9.
If it doesn't fit MODIFY it!!
Cheers BriF
cryoman1965
posted on 16/1/07 at 04:25 PM |
Rejet to 1.65mm/1.7mm as a start. You wont be far out. A lathe would give the most accurate result.
N
cossiebri
posted on 16/1/07 at 04:32 PM |
How much would you charge for inlet manifold for this engine?will you need carbs for pattern or do you sell them as well?
Cheers BriF
