Author: Subject: Finding latching Relays
kango
posted on 18/1/07 at 06:22 PM Reply With Quote
Any body know where I can find then in 12V configuration?
First time VWP don't have what I am looking for.
CairB
posted on 18/1/07 at 06:39 PM Reply With Quote
RS Latching Relays
Of any use?
Howlor
posted on 18/1/07 at 08:06 PM Reply With Quote
I used these guys frequently. The service was superb and some bits I found to be cheaper than VWP.
They have a latching relay.
[Edited on 18/1/07 by Howlor]
owelly
posted on 18/1/07 at 10:39 PM Reply With Quote
Why not make one from a normal relay? Just take the switched output and run it through a 'push to break switch' and back to the relay coil feed.
[Edited on 18/1/07 by owelly]
http://www.ppcmag.co.uk
Confused but excited.
posted on 18/1/07 at 10:44 PM Reply With Quote
Not feasable for the application.
Herman,
The relay suggested by Howlor, from AES, is ideal for what you want, part number 140209, price £14.22 each.
Edit: If you have any problem getting them, I don't mind getting them and sending on to you as I said before.
[Edited on 18/1/07 by Confused but excited.]
kango
posted on 19/1/07 at 04:19 AM Reply With Quote
Thanks all
Will just order and see what happens.
posted on 19/1/07 at 07:49 AM Reply With Quote
maplins, here sell one.
And before ye all scream, it is 12 V but only 2 A, you can use it to switch a fatter relay, so all in, cost should come in under £ 6. assuming you have the space for 2.
