Author: Subject: Caliper position.
3GEComponents
posted on 25/1/07 at 03:38 PM Reply With Quote
Caliper position.
Not sure if this has been asked before, but does the position of the caliper have an effect on the suspension?
eg, if it was mounted at 3 o'clock would it compress the suspension where as if it was at 9 o'clock whould it extend the suspension? or visa versa.
John
MikeR
posted on 25/1/07 at 03:53 PM Reply With Quote
none technical response would be none - assuming identical positioning apart from 3 or 9 o'clock as it gains / looses no additional momentum. Issue would be easy of bleeding / amount of cooling from air rushing past / is it sided - ie this end has to be 'up' for any particular reason.
Bananaman
posted on 25/1/07 at 09:36 PM Reply With Quote
What sort of rear axle set up are you running?
posted on 27/1/07 at 10:31 AM Reply With Quote
It as an effect BUT only on the wheel bearing loads.
