Benzine
posted on 3/2/07 at 11:12 AM |
Feck - Oil leak
Couldn't find anything when searching...Just went out into the garage and saw an oil leak under the MK. As i've not driven it for few
weeks I hadn't noticed this, it's fairly substantial. The coolant level has gone down a lot too. I'm guessing this is bad. Cracked
head/blown gasket? What should I do about it? Drain the oil and coolant? At the moment I don't have the time/money for big repairs so is there
anything I can do to stop it getting worse before I have the time/money to repair?
Thanks for any info
[Edited on 3/2/07 by Benzine]
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make
it moral.
posted on 3/2/07 at 11:18 AM |
I though it was standard on a Pinto...
Got a Pinto, get some drive cleaner...
No offence!
Benzine
posted on 3/2/07 at 11:19 AM |
none taken.
mookaloid
posted on 3/2/07 at 11:20 AM |
No offence!
Huh typical............................
posted on 3/2/07 at 11:23 AM |
sounds odd to me, loosing oil to drive and coolant without trace isnt necessarily one problem. Is there any smeg in the oil (in the filler neck)?
If it was my car, id change the oil/filter unless it has been done within the last few 100 miles, and just keep levels topped up until you can be sure
what the problem(s) is. Look out for poor starting, smokey exhaust and smegged oil / oily water. I dont personally think you have a problem, from the
symptoms, besides an oil leak. Investigate where it is coming from, could be simple ie slack drain plug/filter etc
auzziejim
No offence!
who does that help? go post something about BEC's else where
the cheapest option would be to top fluids up and run it up to temp see what happens if anything
for the price of a gasket set id be tempted to teak the head off and inspect.
james
Benzine
posted on 3/2/07 at 11:33 AM |
No smeg in the filler neck, some slight corrosion around the spark plugs. For some reason my dipstick won't go all the way down so I can't
get an oil level reading.
DIY Si
posted on 3/2/07 at 11:37 AM |
Is the oil level low enough to whip the sump off? It may not help much, but will show why the dipstick won't go in properly.
Sun Tzu, The Art of War
MkIndy7
posted on 3/2/07 at 11:40 AM |
Wonder if its a Water leak... with a few drops of oil in?
1 drop of oil in a puddle of water would look like a massive leak, could be this maybe espescially if you don't know how much oil you've
actually lost.
Hope the car had antifreeze in it.. or has been kept somewhere warm
Benzine
posted on 3/2/07 at 11:42 AM |
Had antifreeze in and has been in a garage all the time.
The dipstick hasn't gone in since i've had a shallow sump fitted, sometimes it does, sometimes it doesn't. It's a case of
fiddling with it for a while. It's the tube that the dipstick sits in that's causing that problem, not the sump itself.
omega 24 v6
posted on 3/2/07 at 11:43 AM |
Where's the oil on the floor in relation to the car and how much??
Look for the usuall front and rear crank seals and around the oil pump. Also check the sump bolts I've seen them become VERY slack on the hotrod
due to the hard ride and vibration (could be similar on a seven).
How much coolants gone??
Try and get the dipstick in cause if the oil level is up and the coolant is dowm
Good luck.
Benzine
posted on 3/2/07 at 12:32 PM |
Just had the car up on stands, there is a crack on the sump. Must have done this the last time I had the car out, it's small (found it after
wiping away oil from the sump) and oil appears from it when you wipe it clean. I guess over the course of weeks a tiny leak could do this.
DIY Si
posted on 3/2/07 at 12:34 PM |
A small spilt in the bottom can empty the entire lot at a surprising rate! Glad to hear it's something minor!
Benzine
posted on 3/2/07 at 01:41 PM |
Got that all patched up now but the dipstick simply won't go in It's a good 2 inches short. I guess I could drain all the oil and put
in the correct capacity in. Does an RS2000 ally sump change the capacity according to the haynes manual? ^__^
Edit: All done. Put new oil in and all liquid levels are back to normal ^__^ Thanks for all the help
posted on 3/2/07 at 04:39 PM |
Glad to see you got it sorted...
As 'most' people know, BEC's aren't faultless...
omega 24 v6
posted on 3/2/07 at 05:59 PM |
An admission. Methinks you might be out of the gang
DIY Si
posted on 3/2/07 at 06:36 PM |
Nah, it's just me breaking mine all the time!
