New Topic New Reply
Author: Subject: Anyone have an M18 fine pitch tap I could borrow for 10 mins!!
gulf zxr
posted on 3/2/07 at 06:42 PM Reply With Quote
Hi guys, Anyone got an M18 fine threaded tap for the upper wishbone I could borrow as I can't get one of my track rod ends in and need to clean it with a tap.
Many thanks
Gulf ZXR
takumi
posted on 3/2/07 at 06:48 PM Reply With Quote
http://cgi.ebay. co.uk/TITANIUM-45-PIECE-METRIC-TAP-AND-DIE-SET_W0QQitemZ260079825911QQihZ016QQcategoryZ63918QQrdZ1QQcmdZViewItem
worth considering, for the money
!excellent value. !
Not the ultra higest quality but with cutting lube should last long enough..
nb; they might be all split dies but dont try widening them..they crack with the slightest force.. M18fine typically.. darn..
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special valves FR22 cam, 4- 1 header.
gulf zxr
posted on 3/2/07 at 06:52 PM Reply With Quote
Thanks for that, only problem I have is that I have a tap and die set that goes up to 12mm but just can't quite justify £34 for a set I will only use for about 5 mins!!
bob
posted on 3/2/07 at 06:56 PM Reply With Quote
I could post you mine,just post it back when your finished M18 x 1.5 fine
u2u me your address if want it and i'll post it 1st thing monday unless you fancy a run out to box hill tomorow.
907
posted on 3/2/07 at 08:25 PM Reply With Quote
I'm a 40 minute drive from Cambridge if your in a hurry and there's no one nearer.
Paul G
bob
posted on 3/2/07 at 08:29 PM Reply With Quote
I'll leave it up to jason(gulf zxr) paul,i've got the adddress but wont post till monday anyway.
907
posted on 3/2/07 at 08:57 PM Reply With Quote
OK Bob. Didn't know he had replied to you.
It's just that sometimes one little thing holds you up, and that can be frustrating.
Been there. Got the T shirt, etc.
atb
Paul G
posted on 3/2/07 at 09:30 PM Reply With Quote
Think I have one but will need to check in the morning. I'm just the other side of Cambridge about a mile from Addenbrookes if it's any help .. When you say 18mm fine what pitch do you mean?
gulf zxr
posted on 3/2/07 at 09:43 PM Reply With Quote
I thought the top wishbone thread was M18 fine ? pitch of 1.5mm?
bob
posted on 4/2/07 at 12:12 AM Reply With Quote
Pretty sure its a spark plug tap size.
New Topic New Reply
