MOz
posted on 5/2/07 at 03:43 PM |
Wheels and Tyres
Another nieve noobie special this.
The car I have bought (MK Indy) is running 17" alloys at the moment.
I plan to use this car on dry summer days only with the possibility of a couple of trackdays a year.
I could recommend motorcycles tyres to do this job but haven't a scooby about the car equivilent..... Can anyone recommend a wheel size and a
sticky but vaguely treaded road tyre for this job????
I guess I am after the car version of the Pirelli Supercorsa / Metzeler Rennsport type tyre (if you know what that is!!!)
Oh, and while we are at it, how do you classify wheel sizes for fitment from a hub/bolts point of view.
Help???
MOz![](/images//smilies/smile.gif)
posted on 5/2/07 at 03:58 PM |
Hi there!
I can't recomend a specific tyre, but assuming your Indy has been built with the standard Sierra running gear you will need...
Ford 108mm PCD wheel bolt spacing on the wheels and they will need to be suitable for stud and nut fitting (as opposed to wheels bolts into threaded
holes in the hubs)
ET (wheel off set) of approx. 35mm
Accepted wisdom suggests that the Ind (and other 7 style cars) perform better on smaller wheels of 13-14"
I'm sure someone will be along to recomend specific tyres. I have Yokohama A539s fitted to mine, but haven't driven it any distance
yet.
HTH
Nick
graememk
posted on 5/2/07 at 04:03 PM |
imho
17" are to big, i'm running 16" only becaus ethey didnt cost me anything
if i was buying again, 15" on 185's for me, but thats only my opinion, others will say different for other type of use
MOz
posted on 5/2/07 at 04:22 PM |
Nick, thanks. V Helpful. I have bought the car off a site member and I'm pretty sure he said it was Sierra/Ford kit.
I think from a visual point of view I'd go for a 15" wheel instead.
What tyres??? Throw some makes and models at me so I can do a search for em...
MOz
posted on 5/2/07 at 04:25 PM |
Yokohama A539 or A520
chockymonster
posted on 5/2/07 at 04:32 PM |
Toyo Proxies R888 - road legal slick
PAUL FISHER
posted on 5/2/07 at 04:50 PM |
As said above R888,toyo's cheapest option,but still a great tyre,AO48'S or A032,Yoko's,or Kumo V70A',all a quite bit more
expensive than the Toyo's,if your looking at replacing the tyres you have got fitted at the moment,then a set of 205 40 17,R888 will cost around
£400,check out www.tyretraders.co.uk.
They still handle ok with 17" wheels on.
Or you could get a set of 15" wheels for track days etc,and leave your 17" for road use,thats the option Sean went for when he had the
car.
![](/galpreviews/a498377-tkcl-snet-06-8835.jpg) ![Rescued attachment tkcl-snet-06-8835.jpg](/gallery/a498377-tkcl-snet-06-8835.jpg) Rescued attachment tkcl-snet-06-8835.jpg
