stats
posted on 1/7/03 at 08:55 PM |
book chassis blunder
Heeelp just starting out and already come to a standing stop. I purchased a "unfinished kit with the tranny tunnel in a straight line down both
sides which did not look to bad untill i tried to fit the enclosed cortina mk3? axle, your there before me, yes it would rub so i have had to cut out
one side of the tunnel to accomodate this.(drivers side) and so far it looks ok. 1st question is do the trailing arms have to be straight, if it does
then i am afraid that the diff will bumb on the chassis. 2nd is do I fit a sierra 1800 pinto(basic book chassis)engine that is driving me round at
the moment"gearbox wider"and if I do will I need to enlarge the front of the chassis to accept the box or should I use 13xflow that came
with the car. some direction would be realy appretiated
thanks
stats
Stu16v
posted on 1/7/03 at 09:40 PM |
Do the trailing arms have to be straight?
Not sure what you mean. Straight as in the design of the arms, or fitment to the chassis?
5spd gearbox should squeeze into a tunnel originally designed for a 4spd box, as long as it is a type 9 (cast unit, separable bellhousing) but you may
have to widen if it is a mt75 box (alloy casing, integral bellhousing).
HTH Stu.
