Author: Subject: BIKE CARBS MISSFIRE
roadrunner
posted on 7/2/07 at 09:19 PM Reply With Quote
BIKE CARBS MISSFIRE
Does anyone know how to balance zx9 carb's, i have a slight missfire on tickover ,or gentle revs, also , how do i know which carb to set, as its only one of the carb's that shuts off.
BRAD
rayward
posted on 7/2/07 at 09:39 PM Reply With Quote
is your car on the road?,
if you could pop over to hull in it one morning next week, i could set them up for you.
[Edited on 7/2/07 by rayward]
posted on 7/2/07 at 09:44 PM Reply With Quote
I used a combo of Colortune and carbtune (both Gunsons). Worked well for me
roadrunner
posted on 7/2/07 at 09:50 PM Reply With Quote
Hi Ray.
No , it's sorn at the moment, is it an easy job, the engine was Tim's and i think Graham balanced them last time.
Brad
TangoMan
posted on 7/2/07 at 10:22 PM Reply With Quote
Easy job but you need a carb balancer.
It will be an imbalance on the tickover settings for each carb. All you need is a facility to balance the airflow at tickover some use a piece of rubber tube and listen for flow but the best way is to source/borrow a carb balancer and set them correctly.
I will have the same issue shortly with my TB's so will be looking for a balancer.
Summer's here!!!!
wment
posted on 24/2/07 at 12:08 AM Reply With Quote
Use the same carb balancer that has been used with SUs for years. I use a UNI-SYN, its not sophisicated but works for all types of applications.
