New Topic New Reply
Author: Subject: Help on pinto engine
david4
posted on 12/2/07 at 07:44 PM Reply With Quote
please could anyone advise me on which radiator to fit into a locost with a pinto 2 litre engine. We have a radiator with pipes that face outwards that we think may come from a cortina. Also has anyone got any designs on alternater brackets. Any advice would be appreciated. Thanks David
flak monkey
posted on 12/2/07 at 07:49 PM Reply With Quote
I used a Mk 1 polo rad on mine. Seems ok, even if it does run a tad on the warm side when standing still for any length of time.
As for brackets:
Sera
http://www.motosera.com
snapper
posted on 12/2/07 at 07:57 PM Reply With Quote
Original radiator that came with my kit was cortina, have replaced it with a twin core one from Robin Hood called a coolman.
It's about twice the depth.
Also added an oil cooler and a big ducted fan for the rad.
Alternator bracket i used was a standard ford ally one with a smaller belt, just ground back the bracket a bit so the alternator would move closer to the block giving me more clearance on the outside of the alternator for the steering shaft.
[Edited on 12/2/07 by snapper]
I eat to survive
I drink to forget
The Baron
posted on 12/2/07 at 08:02 PM Reply With Quote
I used a MKII escort one, fits a treat inside my GTS body work.
I also had to make a alternator bracket to:-
1, Move the alternator in a as close to the engine as possible to free up some room.
2, I used a alternator from a Nissan Micra (it was small)
I welded 3 bits of 25mm x 5mm together to form a U shape, 2 holes to bolt it to the side of the block, a hole in each side for the alternator bolt,
Works a treat.
The Baron
eagle
posted on 13/2/07 at 12:29 AM Reply With Quote
I used the rad of the donor capri
never had any probs with overheating
New Topic New Reply
