New Topic New Reply
Author: Subject: Header Tank
mad-butcher
posted on 8/7/03 at 07:36 PM Reply With Quote
Header Tank
hi all
what header tank do I need.
the set up is, MK Indy, Ford Pinto, Nissan Micra radiator no heater
what sort of header tank do I need ,
the firms fiat fiorino has a lovely oval header tank with 2 outlet pipes and a screw on cap no thermostat cap anywere I can see. is this type alright or do I need one with a thermostat cap like the ugly looking ford thing.
tony
bob
posted on 8/7/03 at 10:31 PM Reply With Quote
TONY
Ive got an astra header tank,it fits on the bulkhead nice and is fed from the pinto waterpump and returns via the inlet and weber carb (pinto)
Havnt tested mine yet but conrods works fine
paulbeyer
posted on 9/7/03 at 12:10 AM Reply With Quote
Eh? you are pumping water into your header tank then out to your weber. That don't make sense, where does the petrol go?
I think I'm missing something here, as usual.
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
auzziejim
posted on 9/7/03 at 10:32 AM Reply With Quote
LOL do you have any pics of that Bob? Im going to use an alloy heder tank from Stuart Taylor, purly for aesthetics really. But i would like to see how your plumbing your cooling system in. Also what rad are you using?
james
SteveO
posted on 9/7/03 at 11:02 AM Reply With Quote
Hi all,
Can anyone briefly describe the cooling pipe routes. i think i'm at a similar stage to Mad-butcher.'got my volvo header tank and an inline fan thermo with a mk supplied metro rad'. webers. Is lower or upper outlet return etc.
bob
posted on 9/7/03 at 06:25 PM Reply With Quote
Sorry lads no pics as no digi cam,but if you contact andy (donut) he should be able to post a few pics.
I'm using the MK 2 escort rad at the moment it has been sealed at the filler,pipes are bottom hose to water pump and top hose to thermostat housing with switch fo rfan inbetween.
Other small pipe on thermo house is blocked off and 1/2 inch pipe from water pump goes to header tank and the outlet from the tank goes to the carbs where it feeds into the block before being pumped round again.
Hope this helps.
donut
posted on 11/7/03 at 06:20 PM Reply With Quote
Bob
The pipe from the water pump to the header tank, does it go in the top or bottomof the tank? If it goes in the top then the water can circulate back out into the inlet mannifold (Paul-this is ok...it goes through to the head!) If it goes in the bottom the water can't get out the top outlet pipe unless the tank is nearly full.
What way are you doing it?
donut
[Edited on 11/7/03 by donut]
santcliff
posted on 15/7/03 at 08:03 AM Reply With Quote
plumbing
Hmm, interesting discussion at exactly the right time for my build :-)
I too have a micra radiatior and i sourced an expansion tank from something in the scrappy that would look nice on the bulkhead. The plan was that the expansion would push water into the expansion tank out of the 'overflow' by the radiator cap. Is this correct?
Additionally, I'm now concerned about my plan to just block off the heater supply/return. Is there a need for water circulation arround this or is blocking off ok?
confused.
s
New Topic New Reply
