Author: Subject: brake flexi's
locoboy
posted on 25/2/07 at 08:22 PM Reply With Quote
brake flexi's
Has anyone used standard production car flexi's on their 7 build?
Im using Sierra callipers front and rear.
just wondering if there are any standard off the shelf parts that have the same thread and will be long enough.
Locoboy
macnab
posted on 25/2/07 at 08:24 PM Reply With Quote
I had considered doing that but got braded instead, worth the extra and it holds its shape better.
macnab
posted on 25/2/07 at 08:29 PM Reply With Quote
just looking at them their 18 1/2 inches long (end to end) with male fitting on both ends, Goodridge TYPE1 FMVSS-106 as supplied my MK all four are identical
locoboy
posted on 25/2/07 at 08:30 PM Reply With Quote
how much were they from MK?
Locoboy
macnab
posted on 25/2/07 at 08:48 PM Reply With Quote
oh god can't remember and just got kicked out of the web when I tried to look. I'm sure its in here http://www.mksportscars.co.uk/downloads.htm the PDF crashed my computer.
they do quite a lot of bits and have always been a very helpful bunch
locoboy
posted on 25/2/07 at 08:51 PM Reply With Quote
Forkin ell
£70! for 4
Locoboy
macnab
posted on 25/2/07 at 09:02 PM Reply With Quote
That’s expensive?
it's a safety thing...
flak monkey
posted on 25/2/07 at 09:03 PM Reply With Quote
Buy them from rally design, they will make crimped goodridge hoses to any length you like, or you can just buy the screw together euroquip stuff and make your flexis for about £15
Sera
http://www.motosera.com
macnab
posted on 25/2/07 at 09:05 PM Reply With Quote
there are issues with the screw together type and the SVA
flak monkey
posted on 25/2/07 at 09:06 PM Reply With Quote
Only if they arent of the correct type.
The manual specifically says that you can use screw togther types, as long as the fitting have an inner support tube and are designed for the application, which the euroquip stuff is!
I have some spare ends to take to the sva with me, incase there are any queries.
[Edited on 25/2/07 by flak monkey]
Sera
macnab
posted on 25/2/07 at 09:07 PM Reply With Quote
hmm but I think you have to be able to prove that the hose is supported on the inside where its going into the fitting
[Edited on 25/2/07 by macnab]
DavidM
posted on 25/2/07 at 09:08 PM Reply With Quote
I used the Rally Design screw together hoses and they passed SVA no problem.
Edited to say: I took a photo of the fittings for proof, but wasn't asked for any evidence.
[Edited on 25/2/07 by DavidM]
macnab
posted on 25/2/07 at 09:10 PM Reply With Quote
cool I just didn't want to try it as I'd probably make a balls of it and the hoses would pop out
flak monkey
See my post above, and this: Rescued attachment brake lines.jpg
Sera
russbost
posted on 25/2/07 at 10:43 PM Reply With Quote
I am shortly hoping to take delivery of a swaging machine to manufacture braided hoses. Should be able to do a set of 4 for around £40 + p&p. U2U if it's of interest.
Alex B
posted on 26/2/07 at 07:44 PM Reply With Quote
Three rubber hoses from Partco....unipart items £ 12.90 all in.........thats Lowcost and safe
Alex
sebastiaan
posted on 26/2/07 at 08:27 PM Reply With Quote
Me me me!
Landrover discovery V8 ones front, and I re-used the sierra fronts at the rear.
Linky to old thread
