<<  1    2  >>
Author: Subject: Oil pressure while cranking over
posted on 12/7/03 at 08:10 PM Reply With Quote
I have a frantic question!
After 6-ish years I actually tried cranking the engine over to see if I could get some oil pressure, before I fill it with water, etc. and an 'engine out' gets really difficult...
My question is, should I see some oil pressure and/or put the oil pressure warning light out when just cranking the engine over with the starter? This is with the plugs out and the coil disconnected.
'cos, at the moment, I don't...
I think oil's getting around the engine, as the engine cranked slowly to start with, then cranked really fast after 10 seconds or so, as if oil had reached the important bits.
Thing is, the pressure gauge reads zero (could be wired wrong of course) and the oil light stays on.
Help!
Fatboy Dave
posted on 12/7/03 at 08:34 PM Reply With Quote
What engine is it?
The V8 is nootorious for this, and you have to either pop the dizzy off and drive the pump with a drill, or flip the pump base off and pack it with vaseline.
If it's an XFlow, then I've heard the same for these, as they can be a bugger to get the pump primed if it has drained. I don't profess to knowing much about the XF engine, so I'll leave the judgements to those who know more about them than I do.
Also, the oil light and gauge both seem to coroborate each other, but check the connections anyway. I take it's electrical, rarther than capiliary? Assuming the sender is OK, then you should at least see *something* when cranking it, rarther than it sitting on the stop down at the f*ck-end of the scale.
I'd go for the oil pump having un-primed itself meself.
Dave
Stop the planet, I want to get off
posted on 12/7/03 at 08:37 PM Reply With Quote
Mmm...
The instruction book said 'don't forget to prime the oil pump before fitting it' and I can't remember whether I did or not.
BTW - it's a crossflow. (forgot to mention it before)
Job for tomorrow, I reckon!
cheers,
[Edited on 12/7/03 by David Jenkins]
Fatboy Dave
posted on 12/7/03 at 08:47 PM Reply With Quote
Doh!
Better get the Vas. out then
Never mind. I shall reveal a tale from my youth involving nine months of paper round hell and a brand new Rover 3.9 short block if you like
Dave
Mark Allanson
posted on 12/7/03 at 09:13 PM Reply With Quote
Instead of Vaseline try neat STP, its kinder on the bearings (leave the vaseline for the chaps!?!)
Fatboy Dave
posted on 12/7/03 at 09:17 PM Reply With Quote
Doubt whether it makes that much difference to be honest. The first thing I would be doing after starting an engine up after that much of a lay off would be to change the oil for something fresh anway.
Unless it's a Land Rover of course. The longer you leave one of them, the better it runs
Dave
Mark Allanson
posted on 12/7/03 at 09:29 PM Reply With Quote
Best thing for a land rover or a deranged rover is a box of swan vesta
Fatboy Dave
posted on 12/7/03 at 09:39 PM Reply With Quote
Oi! I 'eard that!
Probably *not* the best thing to say to someone of my stature Mark
Besides, Land Rover ceased to be in 1996 anyway
Dave
Mark Allanson
posted on 12/7/03 at 09:54 PM Reply With Quote
I did see a land rover with a Dutton Phaeton body on it once, looked quite good, but it did smell funny though
Fatboy Dave
posted on 12/7/03 at 10:03 PM Reply With Quote
That'll be the Dutton
Part of my college project had me turn a Range Rover into this swamp buggy thing for my local off road centre (before the NIMBYs complained too much and they closed down ).
Awesome fun
Dave
Gizmo
posted on 12/7/03 at 11:10 PM Reply With Quote
David, crossflows are indeed terrible for this, given that you've already installed it. Get some jump leads on it (with a running car connected to the other end). This will make the engine crank faster and is usually sufficient to prime the pump. (you did also fill the oil filter before installing it didn't you ?)
---john---
posted on 14/7/03 at 07:52 AM Reply With Quote
To be honest, the pump and filter went on so long ago that I can't remember what I did with them.
My garage was too hot to mess around yesterday, but sometime this week I'll whip off the pump and make sure that it and the filter are full of oil. It's only a 10-minute job anyway.
I tried 2 batteries, but it didn't help - in fact it turned over at just the same speed! I did it with the plugs out anyway, and it's spinning over pretty fast. I used 2 batteries so they weren't hit too hard by the work of cranking over a newly assembled engine.
cheers,
timf
posted on 14/7/03 at 09:34 AM Reply With Quote
Dave have you tried the drill / adaptor method to get some oil pressure?
posted on 14/7/03 at 10:00 AM Reply With Quote
Don't see how that would work - the pump has to be bolted to the side of the block so that it has somewhere to 'suck and blow'! (if you pardon the expression... )
DJ
timf
posted on 14/7/03 at 10:39 AM Reply With Quote
opps
mixed up xflow pinto
Tim
Dave Ashurst
posted on 14/7/03 at 08:12 PM Reply With Quote
Did you fit a new pump when you rebuilt the engine?
The lobes in an old pump can be quite badly scored. That can make it difficult to get the pressure going, even when you think it's been well primed.
Dave
posted on 15/7/03 at 07:36 AM Reply With Quote
It was new (well, recon anyway).
I took the pump off last night - even a gentle turn of the spindle gets oil glooping out of the exit hole. I poured some oil in to top up the filter, just in case. Still the same result.
Tonight's job is to take one of the oil sensors off to see how fast it come out of there.
There's oil in the rocker cover area, which is the final part of the lubrication system, so I reckon oil's getting through - just not very fast.
cheers for the help so far!
stephen_gusterson
posted on 15/7/03 at 09:41 AM Reply With Quote
I wonder, David, if its just that at cranking speed (whatever that is) the pump isnt very efficient and that you will only get pressure at tickover (900 revs or so).
The only comparison I can make is V12 jag. The oil pressure on them is crap. Its normal to start with cold / warm oil and get almost 60psi on tickover.
Once engine is hot, the tickover oil pressure drops to less than 10 psi - about 7 on my car that has a warrnated 55k miles. Pressure went back to about 45 at 2000 rpm.
This is apparently 'normal', and is well documented on the web. On later V12 jag actually connected the oil guage to a simple switch - it read half way when switch closed, and fell to zero when open!!!!
atb
steve
[Edited on 15/7/03 by stephen_gusterson]
posted on 15/7/03 at 10:00 AM Reply With Quote
Steve,
I'm starting to think that way as well.
If I get a good flow from the sensor hole then I can assume that the pump is OK - the sensors are screwed into an oil chamber that's 'next in line' after the pump itself.
My main concern is that the oil pressure switch isn't operating - it's one of the original "if this light comes on, your engine will seize in 0.5 seconds, 'cos you have no oil pressure whatsoever" type!
Fatboy Dave
posted on 15/7/03 at 10:03 AM Reply With Quote
Have you also checked the relief valve?
It may be stuck open. 's an easy job, normally just a bolt/spring/ball afair.
Dave
posted on 15/7/03 at 10:20 AM Reply With Quote
Good thinking...
(bugger - that means I've got to get oily AGAIN!)
Where do I find the valve, once I've got the pump in me hand? Anyone got a drawing, or a link to a useful site?
DJ
[Edited on 15/7/03 by David Jenkins]
stephen_gusterson
posted on 15/7/03 at 03:46 PM Reply With Quote
in 1980 i had a company mk2 escort. at newport pagnel service station the oil light came on. I rushed into the garage (i was late getting home) and bout a half can (2 1/2 litres) of oil and zonked the whole lot in expecting an empty engine.
when I started the car, it was interesting. The crank was hitting the oil, and was creating smoke from oil fires that would have made saddam proud.
moral of story - dont jump to conclusions, it might just be the switch thats broke!!!
atb
steve
Fatboy Dave
posted on 15/7/03 at 04:03 PM Reply With Quote
But a switch_and_guage?
Obviously the wiring gotta be checked and double checked, but I wouldn't have expected both to be duff, especially as they use different senders.
[Edited on 15/7/03 by Fatboy Dave]
Dave
owbow
posted on 17/7/03 at 11:07 AM Reply With Quote
i cranked and cranked my x-flow in the fiesta after it's latest rebuild (dry sumped as well so loads of pipes cooler etc to pump it through)
in the end i just gave up and started it (only to tickover speed, but then it hadn't had a new camshaft so tickover was ok)light went out straight away... just seemed that cranking speed wasn't quite quick enough...?
o.
building it, but someone else is gonna drive it... i must be daft!
posted on 17/7/03 at 12:48 PM Reply With Quote
Steve & 'o',
I think I'll follow your suggestions - if I get a decent flow out of the pressure sensor hole when cranking then I'll leave it alone and wait until I'm ready to start the engine.
Oil is getting to the top of the engine, which is the end of the oil circuit, so I'm no longer excessively worried (but I'll be keeping a close eye on it for the few seconds following start-up )
cheers to all,
<<  1    2  >>
