Author: Subject: Protech spring preload spanner?
tegwin
posted on 5/3/07 at 11:59 PM Reply With Quote
Does anyone know what size "C spanner" I need for the protech adjustable dampers?
I cant for the life of me find anything suitable and its driving me nuts having the front end of the car sat on wooden blocks simply because I cant turn up the preload!!
Dunc
[Edited on 5/3/07 by tegwin]
joolsmi16
posted on 6/3/07 at 12:37 AM Reply With Quote
Hi, I used a "boa constrictor spanner" as the protech as no "C" spanner that will fit. Rescued attachment boa.jpg
Mr Whippy
posted on 6/3/07 at 12:56 AM Reply With Quote
its strange you need one as with mine all I need to do is jack the wheel off the ground and I can turn it by hand, a little WD40 saves the threads.
nitram38
posted on 6/3/07 at 04:41 AM Reply With Quote
You will still need a spanner as hand tight is not enough.
[Edited on 6/3/2007 by nitram38]
russbost
posted on 6/3/07 at 07:56 AM Reply With Quote
Make your own, I did, & this is the Locost site after all.
whitestu
posted on 6/3/07 at 08:29 AM Reply With Quote
I tried a boa constrictor spanner but it wasn't up to the job on mine - the rubber got torn to bits.
I bought a c spanner for a fiver - it was a bit too big so I bent it to fit.
jabbahutt
Protech sell spanners for £5 at their stand at kit car shows. I dare say you should be able to contact them and order one to be sent in the post.
hope this helps
Phil. S
posted on 6/3/07 at 08:31 AM Reply With Quote
I found the standard 1.9 spanner from demon tweeks works fine on mine.
"The unexamined life is not worth living" (Socrates)
"The unlived life is not worth examining" (Kopp)
miegru
posted on 6/3/07 at 09:14 AM Reply With Quote
I don't use a spanner. If I take of the load (which you should do anyway) and 'help'by turning the spring too it is actually quite light to turn.
How more locost can you go...:-)
posted on 6/3/07 at 09:54 AM Reply With Quote
standard 1.9" C spanner works on my Protech shocks just fine - I did cut a bit off the handle length though to make it easier to work on the rear shocks. Also imperative that the wieght/load is off the shocks so as not to risk damaging the threads.
posted on 6/3/07 at 12:37 PM Reply With Quote
Why not simply buy an adjustable C Spanner. Draper make one and I'm sure others do too.
Phil
indykid
posted on 6/3/07 at 04:08 PM Reply With Quote
Phil
because most adjustable ones you see are about 3 or 4 times the price of fixed ones.
i bought a 1.9" one off the gaz stand at stoneleigh a few years back. think it was £4.
tom
