Snuggs
posted on 10/3/07 at 12:24 PM |
HELP
Hi all
I am trying to change the front disks on my Hyundai Lantra and can't work out how to remove the hubs.
Any help would be appreciated.
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
posted on 10/3/07 at 12:35 PM |
Why do you want to take the hubs off?
Surely its just a matter of removing the calipers and taking the discs off?
have you not got the Spanish book??
UncleFista
posted on 10/3/07 at 12:55 PM |
If only it was that simple, I once changed the disks on a Rover (800 ?) and needed to remove the hubs first !
These car designers don't seem to realise that basic maintenance needs to happen
Tony Bond / UncleFista
MikeR
posted on 10/3/07 at 01:10 PM |
no - car designers do realise basic maintenance needs to happen, its just their bosses want jobs to cost a certain amount so they can offset the lower
price of hte car with higher servicing costs.
(call me cynical if you want).
miegru
posted on 10/3/07 at 02:31 PM |
All recent cars (10 year or younger) that I have seen don't need the hub to be removed to replace the disc.
As mentioned before you need to remove the caliper. Sometimes the disc is attached to the hub with one or two screws. I probably will have rusted to
the hub so it might need some motivation to get loose...
My experience is that car manufacturers actually make cars quite servicable. It's cheaper for them to produce, less maintance cost makes their
cars more attractive in cost per km and most important; they need to be serviced safely by 17 year old kids who have received a maximum of 1 hour
training. If they can make easy mistakes that reduce safety the manufacturer will bu sued!
andyps
posted on 10/3/07 at 03:10 PM |
Wasn't the case on the 800 I had.
COREdevelopments
posted on 10/3/07 at 04:02 PM |
never done disks on a lantra but on the coupe they do indeed need the hub removed to seperate the disks as they are bolted on to the hub, IMHO it is a
truely crap idea. have a nice time, and good luck
ChrisGamlin
posted on 10/3/07 at 04:35 PM |
Not as bad as some caravans and trailers, according to my dad the latest Alko axles need the entire stub axle unbolting from the inside in order to
get the drum off, and to top it off, the stub axle is eccentrically mounted so by unbolting it, you screw up the tracking and need to realign it
afterwards!
Snuggs
posted on 10/3/07 at 05:16 PM |
Thanks for all the replies.
Just spoken to a mate who reckons that the wheel bearings usually fall apart when the hubs are removed.
So I will take it to my tame local mechanic on Monday.
miniconverter
posted on 10/3/07 at 06:44 PM |
Disconnect the bottom ball joint, remove the hub nut, pull the hub of the shaft (may need persuading with a large knocking stick), remove brake
caliper, remove track rod end, undo the two bolts holding the hub to the leg, press the drive flange out from the back and the disc can then be
unbolted from the drive flange. Grind the broken inner race off the drive flange and bolt the new disc on. Press the remains of the broken wheel
bearing out of the hub.
Rebuilding is just the reverse of striping but make sure you support the inner race when pressing the drive flange disc assembly back in or you will
need to start again with an other new bearing.
When complete start the other side.
You will need a press
Labour time allowed 2 hours for the pair
Have fun
UncleFista
posted on 10/3/07 at 06:54 PM |
Was a few years ago, was one of the big Rovers, after Honda stuck their oar in. Big unreliable P.O.S. IIRC
