ricklawn
posted on 14/3/07 at 08:11 PM |
fitting fuel pump
Hi Guys
just got a new facet pump and fixing kit..
pump comes with earth wire as does fixing kit . Do i need both ????? if so why?
Rick![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif) ![](/images//smilies/smile.gif)
flak monkey
posted on 14/3/07 at 08:12 PM |
Its to earth the pump body i think. Not got one on mine at the moment (maybe i should add one!). Works ok...
Sera
http://www.motosera.com
ricklawn
posted on 14/3/07 at 08:15 PM |
pump body has one fitted.
i dont see the relevence of earthing it with the mounting as well????????????
lsdweb
posted on 14/3/07 at 08:17 PM |
Is the pump rubber mounted? That would explain a lot!
ricklawn
posted on 14/3/07 at 08:20 PM |
it fitting kit is just like 2 rubber mushroom fittings that you fasten an exhaust with
lsdweb
posted on 14/3/07 at 09:04 PM |
You need to earth the pump then!
ricklawn
posted on 14/3/07 at 09:32 PM |
Cheers![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
miegru
posted on 14/3/07 at 10:12 PM |
The idea is to earth everything metal that is isolated from the chassis. Under no circumstances should if be possible for the fixing or pump to store
static energy that will possible lead to spark and ignite leaking fuel.
Bit farfeched but I just wired it up. The SVA inspector actually remarked on it. He told me that these details told him that the wiring was done with
care.....
He told me that he basically will find faults in all cars if he wants. But if the general impression is ok he is a bit milder on minor violations.
Right or wrong; I would wire it up.
westcost1
posted on 15/3/07 at 03:52 PM |
My facet pump came with instructions telling you to earth the pump across the rubber cotton real mount so yes earth it![](/images//smilies/smile.gif)
