chrisg
posted on 20/3/07 at 10:27 PM |
Zetrec 2.0 - Which bike carbs?
Hey Up
Which bike carbs would be best for a 2.0 litre Zetec engine?
cheers
Chris
bodger
posted on 20/3/07 at 10:34 PM |
Some people are using GSXR 600's or 750's.
grahamgg
posted on 20/3/07 at 10:39 PM |
R1 carbs are popular, but any from a 600 upwards,,
Nick Rogers
posted on 20/3/07 at 10:42 PM |
I'm using R1 carbs
UncleFista
posted on 20/3/07 at 10:44 PM |
quote: Originally posted by chrisg
Hey Up
cheers
Chris
If you're going with megajolt for sparks, try and get a set of carbs with a TPS included, saves a bit of hassle later
Tony Bond / UncleFista
chrisg
posted on 20/3/07 at 10:48 PM |
Hey Up
cheers
Chris
Will do Tony - Which ones have a TPS?
givemethebighammer
posted on 20/3/07 at 10:51 PM |
I've got Honda Blackbird ones on mine
(they have a TPS)
[Edited on 20/3/07 by givemethebighammer]
UncleFista
posted on 20/3/07 at 11:27 PM |
I'm not sure Chris, early days for our Zetec I "think" the later the bike, the more likely to have a TPS, something to do with
emmisions on later bikes ?
chrisg
posted on 20/3/07 at 11:37 PM |
Thanks chaps.
so let's start a list(!)
Blackbird
and....
Chris![](/images//smilies/bigsmile.gif)
fellowes
posted on 20/3/07 at 11:54 PM |
I have 1999 R1 carbs tied to a Boggs Brothers manifold. Had the head ported and planed .025 inches. Estimate the engine is doing around 170 hp.
Sounds sweet and awesome performance. I had to do some fiddling with the main and idle jets to get the right size (and you can buy these as std
sizes). Am very pleased ![](/images//smilies/wink.gif)
tim windmill
posted on 21/3/07 at 08:10 AM |
zx9 carbs e model have tps
andyace
posted on 21/3/07 at 08:34 AM |
Thats what I have, they are 40mm
cryoman1965
posted on 21/3/07 at 08:56 AM |
GSXR 600 srad,
ZX6/7/9 later models
R1, although they fetch stupid money£150+
posted on 21/3/07 at 09:25 AM |
I'm using ZZR1100 carbs but they have no TPS. I may go for some zx9 carbs or try and fit the TPS off the Ford inlet manifold.
nige
posted on 21/3/07 at 09:52 AM |
bike carbs
i got a set o blade carbs off flea bay with t.p.s.
£30 cheap as chips
r1 and black bird are more hi cost
[Edited on 21/3/07 by nige]
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
chrisg
posted on 21/3/07 at 10:26 AM |
Thanks everybody - gives me a start!
bob
posted on 21/3/07 at 11:33 AM |
Blade carbs seem a better price, and luckily bogg bros recomended them for ease of set up so thats what i did.
UncleFista
posted on 21/3/07 at 02:02 PM |
Chris, have a word with Malc at Yorkshire engines. In the last lot of TBs he had up for sale, there were a few sets of carbs available. He specialises
in low-milage engines, he might have something ?
TangoMan
posted on 21/3/07 at 07:13 PM |
Anything over 38mm should be OK for a standard 2.0 Zetec.
I opted for 42mm TB's and think they are too big for a standard engine. Small throttle openings at low revs gives 100KPa so it makes it very
sensitive at low throttle.
They will be good once I tune up though!!
Most bike carbs come with TPS but if not they can be sourced from Maplins very cheaply.
Summer's here!!!!
jacko
posted on 21/3/07 at 08:35 PM |
Kawasaki zx9r ---e carbs have tps and are 41mm
Jacko
chrisg
posted on 22/3/07 at 10:53 PM |
You know when you go on e-bay and you get carried away and bid on lots of stuff, just in case?
Well I appear to have bought some GSXR750 carbs. For £10.50.
Any TPS on those?
Chris
Edit I've solved this one myself - no TPS, what does Maplins list them as?
(It's not Throttle position sensors BTW!)
[Edited on 22/3/07 by chrisg]
