Avoneer
posted on 24/3/07 at 09:28 AM |
Trolley Jack mod to go under 7
After thinking about this for ages and struggling with my trolley jack on many occasions to get it under my Avon and the Bitsablade, I came up with
this easy solution:
Chop off the old top cup thing:
Avoneer
posted on 24/3/07 at 09:29 AM |
And weld on a flat plate:
Avoneer
posted on 24/3/07 at 09:30 AM |
It will fit under anything now and has a better flat lifting base.
Just make sure the main arm won't hit the bottom of your plate before you cut off the old cup.
Pat...
[Edited on 24/3/07 by Avoneer]
posted on 24/3/07 at 09:32 AM |
Your innovative approach never fails to astound Pat... or are you bragging you have a welder?
We need to tyre kick and stuff... you settled in your new home yet? I'm frequently around the Dewsbury area....
posted on 24/3/07 at 09:46 AM |
Running the car on to a short plank of wood works for me.
ricklawn
posted on 24/3/07 at 09:50 AM |
for an easier solution leave 2 scaffold planks in place in garage, push or drive car on to planks, hense raisingcar 2 inch.
problem solved, also i cann't weld as in solution one![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
ricklawn
posted on 24/3/07 at 09:51 AM |
i realy must speed up on my typing![](/images//smilies/tongue.gif) ![](/images//smilies/tongue.gif)
chris_harris_
posted on 24/3/07 at 10:05 AM |
And if you get some rubber sheet and add stick that to the plate, you won't scratch your pride and joy and it won't slip either!!
Regards Chris
posted on 24/3/07 at 10:34 AM |
I just take the cup off.
It fits under then and it's only held on with a split pin through the centre pin
![](/galpreviews/a528439-oldtop.jpg) ![Rescued attachment oldtop.jpg](/gallery/a528439-oldtop.jpg) Rescued attachment oldtop.jpg
SeaBass
posted on 24/3/07 at 11:27 AM |
I modded my jack in exactly the same way... Best thing I've ever done - no pissing about with blocks of wood or scaffold poles. No moving the
car.
Its fine as long as you remember what a jack is for lifting not supporting. Once I've got the height the axle stands go straight under. Even on
something as light as the seven you can get some nice internal injuries if it falls on you.
RazMan
posted on 24/3/07 at 11:49 AM |
I did EXACTLY the same mod a few weeks back, including pop rivetting two layers of rubber mat on top to make it non-slip & non scratch.
Raz
Avoneer
posted on 24/3/07 at 09:00 PM |
Hi Steve,
Had a welder ages - not that I can weld though - barely get by!
Yep, settled in, until the extension starts in the month or two.
I'm in on Tuesday after about 4.15 if that's any good?
Pat...
JB
posted on 25/3/07 at 08:01 AM |
Low Profile Jack
I had the same problem. So looked into buying a jack.
Sealey sell one 80mm to 795mm !! which was on offer last year at 50%. I bought one. The only problem its a big heavy thing but its great. The sort of
thing you buy once and will last a life time. Theres no way I would have bought at full retail though.
HERE
posted on 25/3/07 at 12:16 PM |
The bike shop was having a clearout last year and I got a 2 ton Bradbury jack off them as it was going to the scrap not working. I filled it up with
oil and it's been fine since. It also has a quick lift start so the first stroke lifts till it hits something solid.
posted on 26/3/07 at 09:09 AM |
That's right, ALWAYS use axle stands to support.
I lift mine on just the trolley and after a couple of days, it had lowered itself by a few cm. I never crawl underneth without solid support.
Even on something as light as the seven you can get some nice internal injuries if it falls on you.
And even if it doesn't crush you,. it will rest on your chest preventing you from breathing so do not take chances.
