darren(SA)
posted on 21/7/03 at 06:22 PM |
cortina brake light sensor?
Hi guys, nearly finished my wiring but was halted by the fact that the cortina master cylinder doesn't have a pressure switch built in. Should
this switch be fitted in my plumbing? if so what do you need?
thanks
darren
theconrodkid
posted on 21/7/03 at 07:30 PM |
you talking brake light switch?use a vw golf mk1 type complete with T peice
who cares who wins
pass the pork pies
darren(SA)
posted on 22/7/03 at 10:15 AM |
yes brake switch, T piece where rear brake pipe goes into master cylinder?
thanks
darren
spy
posted on 22/7/03 at 01:21 PM |
Darren,
t-peice anywhere convenient in the pipeline for the FRONT brakes (rear brakelines generate less pressure so you have to brake a lot more heavily
before the brake lights come on)
If possible, fit the switch with the wires pointing towards the ground. This will get rid of a point where air can get trapped in the tee peice
during bleeding.
darren(SA)
posted on 23/7/03 at 08:17 PM |
Sounds good thanks!
(did a bit of phoning around, got some "huh's" but i'll come right thanks!)
cheers
James
posted on 25/7/03 at 10:53 AM |
quote: Originally posted by darren(SA)
Sounds good thanks!
cheers
Can't you still buy a MK1 Golf new in SA? Can't be that hard to get spares!
James
theconrodkid
posted on 25/7/03 at 05:06 PM |
twas fitted to lotsa cars n vans,try vw lt truck or rover metro
who cares who wins
pass the pork pies
Jon Ison
posted on 25/7/03 at 08:56 PM |
or a micro switch resting on the pedal, no plumbing worries then.
the Cortina don't have an inline brake switch, its under dash resting on pedal............
