Author: Subject: Sierra Gearbox
LBMEFM
posted on 26/3/07 at 06:19 PM Reply With Quote
Sierra Gearbox
Hi
I have a 1992 Ford Sierra 1800cc 5 door manual hatchback. Would the gearbox be a type 9.
Barry
big_wasa
posted on 26/3/07 at 06:22 PM Reply With Quote
yep
robertst
posted on 26/3/07 at 10:39 PM Reply With Quote
u sure? i think by 1992 they switched to the MT75 one...
Tom
chrisg
posted on 26/3/07 at 11:22 PM Reply With Quote
89 was the Mk1/Mk2 change over, but typical of Ford, they used the type nines until they ran out!
I would have thought a 92 would have been a MT75.
I believe that reverse is in a different place on the gate but I'm buggered if I can remember which is which!
Chris
24vseven
posted on 26/3/07 at 11:45 PM Reply With Quote
type 9 reverse is up left and up ie next to first
mt75 reverse is below position 5 also type 9 has push down to engage rev
mt75 has a lift up bit on the knob
hope it helps
big_wasa
posted on 28/3/07 at 08:11 PM Reply With Quote
sure the mt75 was only fitted to 2l in 2wd and the 2.9 v6 in 4wd
I have two late K 1.8 sierra's both have type 9's
Mark Allanson
posted on 28/3/07 at 08:56 PM Reply With Quote
On the late 2.0's, the type 9 was fitted to the pinto, and the MT75 to the twincam
DarrenW
posted on 30/3/07 at 09:15 AM Reply With Quote
My h reg 2.0 DOHC donor was MT75. That wa sthe best bit of the car and no use to me
markf
posted on 25/4/07 at 09:18 PM Reply With Quote
gearbox
hi all,
as im new to this, can some one tell me, does it make a difference wether you have a mt75 or a type 9, if so what is the difference, and how does it affect the build
cheers
mark
a.goodarzi
posted on 17/5/07 at 11:50 AM Reply With Quote
