bodger
posted on 27/3/07 at 09:58 AM |
R1 Clutch
Before I pull the clutch cover off again. Is is possible to rotate the clutch lever arm about 90deg so that it's pretty much a straight cable
run to the clutch pedal?
Anyone tried?, Any problems ?
Bob C
posted on 27/3/07 at 10:03 AM |
I think you can just pull off the circlip & have the arm on any of the splines. The wee exterior return spring might not do much any more (like
mine doesn't....)
Bob
smart51
posted on 27/3/07 at 10:13 AM |
If you remove the clutch cover (certainly on early R1s) the clutch arm is attached to a pinion. A small rack pulls the clutch plates apart. There is
no reason why you cannot rotate the arm to any position you like, however as has been mentioned, the return spring probably won't be engaged if
you do.
What are you thinking of doing? Using a rod to connect the pedal to the clutch lever?
[Edited on 27-3-2007 by smart51]
zxrlocost
posted on 27/3/07 at 10:43 AM |
I rotated my arm so I could have it in line with the pedal as colin says
[Edited on 27/3/07 by zxrlocost]
ChrisGamlin
posted on 27/3/07 at 11:12 AM |
Same here, rotated mine similar to what Rich Miles did on his Striker install
TimC
posted on 27/3/07 at 12:47 PM |
Have you guys just done away with the spring then?
(Was actually pondering this myself yesterday.)
Ta
R1 STRIKER
posted on 27/3/07 at 02:07 PM |
Rotated mine and wound the spring up a bit more so it still works!
Ben.
ChrisGamlin
posted on 27/3/07 at 03:56 PM |
Yep I just modded the spring too.
Moospeed
posted on 4/4/07 at 01:25 PM |
me too - pic here http://moospeed.fotopic.net/p32544976.html
Dead straight cable, less than a metre long and direct into the pedal
- Moospeed
