lough
posted on 28/3/07 at 09:31 AM |
Zetec rod bolts?
Has anyone bought any bots for a Zetec from the States, I have been looking at them on E-bay.com and they are listed as 2.0 L Zetec?
http://http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&viewitem=&ru=http%3A%2F%2Fsearch.ebay.co.uk%3A80%2Fsearch%2Fsearch.dll%3F
cgiurl%3Dhttp%253A%252F%252Fcgi.ebay.co.uk%252Fws%252F%26fkr%3D1%26from%3DR8%26satitle%3D8061414518%26category0%3D%26fvi%3D1&item=8061414518
lough
posted on 28/3/07 at 09:35 AM |
Link didn’t work, see item number 8061414518. I will work on the link
garage19
posted on 28/3/07 at 10:28 AM |
I have bought the from the states.
What zetec engine do you have?
The silver tops have a 8mm rod bolt and the black tops have a 9mm rod bolt.
The americans only got the black top in 2ltr version.
If you want silver top rod bolts you have to order them for a 1600 zetec which was the only silver top version the sates got.
Werner Van Loock
posted on 28/3/07 at 10:34 AM |
That's not gona fit I think, thought euro zetec's use 8mm bolts, and US zetec's 9mm
Read it somewhere, but can't find it anymore
ah, garage19 beat me to it and just confirmes what I just told
though didn't know about the black-/silvertop difference
[Edited on 28/3/07 by Werner Van Loock]
http://www.clubstylus.be
lough
posted on 28/3/07 at 10:43 AM |
Thanks for that I think I will strip the engine down then order a set once im sure of the size. What about the rest of the bolts, main’s, flywheel
etc.
grahamgg
posted on 28/3/07 at 11:38 AM |
Burton power products is a good source if you need mail order
procomp
posted on 28/3/07 at 01:07 PM |
Hi here you go a link to europe suppliers of ARP products. LINKY
cheers matt
Danozeman
posted on 28/3/07 at 04:21 PM |
Do u want standard ones?? I found ford to be the cheapest.
zetec
posted on 28/3/07 at 05:11 PM |
I called Dunnel on the subject last week. They don't use ARP for their engines anymore, they now source their own which are reusable...About
£9.00 each I think.
Good eggs at Dunnel...Loads of info and no hard sell.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
lough
posted on 29/3/07 at 08:18 AM |
I’m looking to build a relatively standard engine running on GXSR 600 throttle bodies, and have been advised that I should upgrade the main and bigend
bolts, after looking on e-bay .com saw these ones available from the states and don’t know if to go for these or buy from the UK. Any advice on bolt
selection or requirements would be welcomed.
1800 silver top zetec.
zetec
posted on 29/3/07 at 10:30 PM |
If you keep the revs below 7K then no need to change either, above 7K big end bolts need doing, never heard of issues with mains.
Schrodinger
posted on 30/3/07 at 08:13 AM |
I think you will find you will also need to machine the caps to fit the ARP bolts as they are chamfered to the head but the caps are square.
lough
posted on 31/3/07 at 07:09 PM |
Thank's for the info.
Richard
