stevebubs
posted on 8/4/07 at 07:01 PM |
Spraying.....
Ebay
Item 200089892660
Comments on suitability for spraying a car?
rayward
posted on 8/4/07 at 07:03 PM |
looks ok, but thats just the mask, you would still need filtration components aswell.
Ray
blakep82
posted on 8/4/07 at 07:11 PM |
and an air regualtor, unless you want the full pressure of you compressor blasted in your face
________________________
stevebubs
posted on 8/4/07 at 07:16 PM |
Got a few regulators around...any special filter required?
davie h
posted on 9/4/07 at 12:00 AM |
dont have the compressor in the same place as you are painting or you will just be breathing in contaminated air if the compressor is in a clean
enviroment i dont think you would need any special filter although i may be wrong
stevebubs
posted on 9/4/07 at 01:22 AM |
Guessing I'm gonna need something to filter contaminants from the tank / pump.
Would run 2 compressors - 1 located in "fresh air" and providing air to the mask. The second would be located closer and would have the
sole task of running the gun.
turbodisplay
posted on 9/4/07 at 08:06 AM |
Isn`t the air from a compressor dirty (even with an inline filter)?
What do you think of the double face respirators with cartridges?
Darren
miniconverter
posted on 9/4/07 at 09:00 AM |
You must use a filter even if the compressor is taking in clean air.
You can also only use certain types of oil in the compressor.
Go and get advise from a refinishing supplier other wise you might as well just breath the paint fums in
posted on 9/4/07 at 10:29 AM |
I use one of these
Disposable mask . I get them from a local supplier, just use them then get a
new one. You can't smell the paint you are using while wearing one.
nige
posted on 10/4/07 at 09:52 AM |
mask
i second what peteff says
ive just sprayed my panels over easter
and used a similar mask excellent fit
not taste and no coloured snot
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
stevebubs
posted on 10/4/07 at 11:24 AM |
Ok..but what types of paint are/are not safe to use with this?
Presuming 2Pack is probably not?
posted on 10/4/07 at 07:54 PM |
2 pack what?
2 pack isocyanate shouldn't be used anywhere without a full filtration system. I use the 3m mask with cellulose or synthetic enamel no problem.
2 pack polyurethane or isocyanate free acrylic should be safe but it's up to you to decide what you want to use.
